DAZ|Studio F.A.Q (Last Updated: 2025 Feb 12 6:12 pm)
Actually, the DAZ content is even more limited - it is stated that the content will cease to work after a while. DAZ already mentioned that they will include some kind of DRM, so they can give away freebies that work only for a certain time. Since Poser don't offer such capabilities, they probably will not support an poser importer for DAZ-Files since that would make the DRM obsolete. But DRM can make sense here. Imagine a TRY-BEFORE-BUY-solution, where you can test D|S-Models for a day or two before you actually have to buy them. Just my two cents, Uwe
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
You can get every Model from DAZ as a poser model - unrestricted, because you cannot retrict poser models. But DAZ can restrict .DAZ-Models obviously. The Content delivered with the beta is Time-Limited and works only up to May 10th. If you could export it as poser content, the time-bomb would be removed. This is probably noct what DAZ wanted to do.
-"Amazing
Grace" Hopper
Is D/S content (for example the Temple Ruins free download) different from the non D/S content of the same name? If it is, in the future if I buy D/S content can it be converted for use in Poser? It looks like Poser content can be used in D/S with no problem... so if content is in different formats, is a D/S format better in any way? Thanks! Steve
