Mon, Jan 27, 11:59 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Poser Mac question
RAWOLF ( ) posted Fri, 07 May 2004 at 2:36 AM · edited Mon, 27 January 2025 at 11:51 AM
Weird thing happened after i installed osx panther... poser 4 (which runs slow in classic anyway) quits 90% of the time (render or add character it doesn't matter) I guessed it might do so due to poser 4 not being recommended for use in classic. So started up in os 9.2 (this i'm real worried about)..same deal only less of a % of quits (got to pull off a render or 2). I uninstalled then installed again but it still acts up. ???@#%$! Gonna get more ram to see if it helps, it's been on my to do list for 2 years, I'm at the bare min. of (a 256 meg ram factory installed) RAM gonna get a 512 soon .Time for poser 5?
nomuse ( ) posted Fri, 07 May 2004 at 2:51 AM
Huh? I dunno about running in "classic" mode but I've been using Poser4 in a 9.1 boot for years. That does sound like very little RAM tho. I'm surprised you can even boot into Panther with that!
estherau ( ) posted Fri, 07 May 2004 at 3:31 AM
Poser 4 does run very slow in classic with panther, but you're right it should be okay in )S 9 boot. So get more ram. Poser 5 doesn't run as fast as poser 4 used to run in jaguar BTW. I was quite disappointed, but there are other compensations like dynamic clothes. Love esther
MY ONLINE COMIC IS NOW LIVE
dan whiteside ( ) posted Fri, 07 May 2004 at 8:31 AM
I'm wondering how much RAM you have assigned to Poser 4 - click the p4 application icon, hit open-apple + "I" and then open the memory tab. Panther needs 128MB so on a 256MB machine I'd try setting the Preferred Size field to 120000 (120mb) or maybe a little less. It may be that you're still set for the p4 default of 70MB. That extra 50mb could make a difference. You can also track how much RAM is left by opening the System Prefs., clicking the OS9 icon and clicking the Memory/Versions tab (above). It'd still be better to get more RAM. HTH; Dan
zorares ( ) posted Fri, 07 May 2004 at 12:21 PM
Geez, I haven't ran Poser PPP since I upgraded to Poser 5. I upgraded just so I wouldn't have to mess with Classic. You might consider it.
http://schuetzenpowder.com/sigs.jpg
Miss Nancy ( ) posted Fri, 07 May 2004 at 1:45 PM
I've been hearing that Panther needs at least 768 MB. However, I would suggest at least 2 GB to deal with Unix VM and page-out inefficiency.
nomuse ( ) posted Fri, 07 May 2004 at 1:51 PM
Two gig? Now you're being silly. I was running Jaguar with only 320 megs of physical RAM available -- was kinda hard to shoehorn anything bigger than Wingz in there with it, though. I tend to leave the memory on Power4 above 180, tho. And my sole millenial figure is only a 1.0
dan whiteside ( ) posted Fri, 07 May 2004 at 2:15 PM
Attached Link: http://www.apple.com/macosx/upgrade/requirements.html
I got the 128MB size from the Apple website but I should have said that that was the minimum.
RAWOLF ( ) posted Fri, 07 May 2004 at 2:44 PM
Thanks to all. Dan, as far as memory it's using the default. SO... should i up it or will Virtual memory compensate. But i still don't know why 9.2 won't keep it stable it ran fine on 256 before. Or ...well screw it i'll just get more memory and poser 5, then i'll cry about something else..being poor.
nomuse ( ) posted Fri, 07 May 2004 at 3:37 PM
I'm still questioning choice for going to Poser5 in search of INCREASED stability. Unless you mean the ability to run in OS10.3 native. Virtual memory is a poor substitute for something like Poser. You'll slow down the program too much to be comfortable. RAM, even in my cash-strapped opinion, is cheaper than time spent struggling with poorly-running software. I finally got around to getting the 9.2.2 upgrade. I haven't noticed any change in Poser yet but I'll keep you posted if you care.
dan whiteside ( ) posted Fri, 07 May 2004 at 7:48 PM
rawolf - I'd give it a try, the worst you'll get is more out of mem errors. I agree with nomouse, VM works poorly with an app like Poser. Poser 5 has worked really well for me under 10.2 and 10.3 (except for it being really slow. I had more crashes with P4PP under 9.2.6 then I do with P5OSX. Don't have a clue as to why it worked before, but memory issues may be one of the reasons CL doesn't support P4 under OSX. Best; Dan
RAWOLF ( ) posted Fri, 07 May 2004 at 7:49 PM
So p5 still suffers from bugs on osx 10.3 and isn't good purchase if i want stability? I increased the memory for the app. on 9.2 (forgot that i did that the last time it was installed) it works ok now.... but poser4 is the only app. (next to the mac converter & installer) that run in classic/9.2 all my other apps. (photoshop etc..)are osx. Honestly would p5 be a recommended purchase since i don't really use 9.2. Do they make a mac converter for osx or does p5 recognize certain files and do it?
estherau ( ) posted Fri, 07 May 2004 at 8:15 PM
I still run everything through mac converter in case I want to use P4 for something, but I have poser 5. It's quite slow in panther but good in other ways. I may need more than the 1 gig of ram that I've got and it's only seeing one of my two 500mghz dual processors. apparently processor power and ram is what makes speed differences in poser. Love esther
dan whiteside ( ) posted Fri, 07 May 2004 at 8:25 PM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1373665
The bugs in Poser 5 are really minor and I'd certainly rather run P5 then P4 under Classic. See the link above for MartinC's comments on Maconverter for OSX. This is an older post - things may have changed since CL was aquired by E-frontier. P5OSX does conform to the PC format except for reading thumbnails (you get the shruging guy) - this, to me, is the worst bug in P5. -Dan
