Forum Moderators: RedPhantom
Is it an obj you have made yourself? What happens if you import your obj? Does it fit then? The obj itself must be in the correct size.
hi, first thing is that you are dealing with max or something simlar you need to scale down the model... using object scaller 3c which is a freebie. you need to scale down 100. If you need some help I can help. :D I know how fustrating conforming figures can be. :D one question which program are you using to model the clothing? Seraphira
Now that sounds like a bug of some sort. So if you import your obj at 100% it has the correct size, but when it's conformed it grows? O.o
I'm trying to make a conforming clothing item using Quick Conform, but when I click on the little shrugging guy to bring it up in Poser, the clothing item is gigantic! Like 5 times the size of my person. Any idea why it is doing that?
