Thu, Feb 20, 2:08 PM CST
Forum Moderators: RedPhantom
Subject: Conforming clothing obj is gigantic! What gives?
Cyhiraeth ( ) posted Mon, 10 May 2004 at 2:07 AM · edited Tue, 18 February 2025 at 6:16 PM
I'm trying to make a conforming clothing item using Quick Conform, but when I click on the little shrugging guy to bring it up in Poser, the clothing item is gigantic! Like 5 times the size of my person. Any idea why it is doing that?
TrekkieGrrrl ( ) posted Mon, 10 May 2004 at 2:55 AM
Is it an obj you have made yourself? What happens if you import your obj? Does it fit then? The obj itself must be in the correct size.
Seraphira ( ) posted Mon, 10 May 2004 at 4:09 AM
hi, first thing is that you are dealing with max or something simlar you need to scale down the model... using object scaller 3c which is a freebie. you need to scale down 100. If you need some help I can help. :D I know how fustrating conforming figures can be. :D one question which program are you using to model the clothing? Seraphira
Cyhiraeth ( ) posted Mon, 10 May 2004 at 9:51 AM
Oops, sorry...I used Wings 3d to model it and if I import the obj, it appears to be of normal size. It's only when I use Quick Conform and then try to use the resultant cr2, that I get this gigantic obj.
TrekkieGrrrl ( ) posted Mon, 10 May 2004 at 1:04 PM
Now that sounds like a bug of some sort. So if you import your obj at 100% it has the correct size, but when it's conformed it grows? O.o
Cyhiraeth ( ) posted Mon, 10 May 2004 at 2:01 PM
It gets weirder....I imported it back to Wings to have a look at it, loaded the figure to compare size and lo, it was gigantic...so, I rescaled it and am starting from scratch.
