Tue, Jan 7, 4:33 AM CST
Subject: Texturing Question - Tiled texture to Untiled texture
Richard T ( ) posted Sun, 09 May 2004 at 11:14 PM · edited Tue, 07 January 2025 at 4:32 AM
Hi I have a commerial architecural poser character which uses tiled textures. I wish to use my own texture on this model and was wondering what is needed to allow me to apply a texture so that it doesn't tile. I am using Poser Pro Pack. TIA. Richard Taylor
byAnton ( ) posted Mon, 10 May 2004 at 2:21 AM
If the object is built so that every texture you apply ends up tiling then you get get UvMapper from www.uvmapper.com and remap it. Not sure if that answers it.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
Richard T ( ) posted Mon, 10 May 2004 at 4:01 AM
Thanks very much, Anton. I will give it a go, I will learn something new.
EnglishBob ( ) posted Mon, 10 May 2004 at 5:10 AM
Couple of tips - UVMapper will load a PP2 file with embedded geometry, if that's what you have - just drag-and-drop your file onto the UVM window. If your prop has separate materials defined for the tiled parts, you can use Edit > Select > by Material... to isolate them and remap each part one by one.
maclean ( ) posted Mon, 10 May 2004 at 2:29 PM
Coupla more tips. It's easy to spot tiled obj files because, when you open one, uv mapper will tell you it has out of range uv coordinates. Don't correct them, just let it load and do it yourself. The tiled material will be outside the uv mapper 'frame'. What you have to do is select it, then shrink it. You can do this by either pressing the / key on numpad, or by pressing SHIFT-minus (the minus key on the numpad). Shrink it until it's inside the screen area, then save the obj (maybe with a new name). mac PS I also make architectural models and I avoid tiled textures like the plague.
