Sun, Dec 1, 10:11 PM CST
Subject: Transmap shadows
Nukeboy ( ) posted Sun, 09 May 2004 at 8:07 PM · edited Sun, 01 December 2024 at 10:07 PM
The sphere has an image and transmap applied, yet it is the sphere that is casting the shadow. Anyway to have the transmap cast the shadow? I'm sure I haven't had this problem before, and yes, the black in the transmap mask is black (0,0,0).
AgentSmith ( ) posted Sun, 09 May 2004 at 8:55 PM
Yeah, hate that. Make sure the black on your trans map is pure black. Other than that, I don't know, I have had that problem sometimes to the point, I couldn't get rid of it no matter what tweaking I did. AS
Nukeboy ( ) posted Sun, 09 May 2004 at 9:57 PM
Okay, sounds like lots of work with negative lights... :>)
AgentSmith ( ) posted Sun, 09 May 2004 at 11:30 PM
Oh, you can start increasing your transparency, that WILL get rid of it, but obviously it will begin to make your veggie leaf slightly transparent also. ;o/ AS
GROINGRINDER ( ) posted Mon, 10 May 2004 at 1:29 AM
I keep forgetting to check the "blend transparency" setting when using trans maps.
shadowdragonlord ( ) posted Mon, 10 May 2004 at 4:11 PM
In this case, I would say that the black is at 1 or 2, instead of absolute Zero, in your Alpha image... Check it out, and try it again. Another thing I noticed, alpha-channels don't work on Metaballs OR with volumetrics. (shrugs)
Nukeboy ( ) posted Mon, 10 May 2004 at 4:48 PM
Strangely weird, I deleted that sphere, recreated it with the same image and mask and it worked fine... the really weird thing is that Blend Transparency was NOT checked. I think Bryce changes the rules on us once in a while just to keep us humble...
AgentSmith ( ) posted Mon, 10 May 2004 at 11:17 PM
Volumetrics and trans maps. They do work, but I have found that for me to make it work, I have had to use a totally different looking map for the trans. Meaning, I took some pics of flames from a campfire, I took one specific pic of flames against a dark/black background, and loaded that up. Then I used a different flame pic for the trans. If I used the same pic for both it wouldn't work (very well) AS
AgentSmith ( ) posted Mon, 10 May 2004 at 11:26 PM
What I mean. AS
AgentSmith ( ) posted Mon, 10 May 2004 at 11:27 PM
Some examples of volumetrics from picture textures that I had made, using two different maps each. AS
shadowdragonlord ( ) posted Tue, 11 May 2004 at 4:30 PM
Good stuff, AS, thanks for the tips! What I meant was simply that shining a volume-visible light through a 2D pict-based object produced distinct square edges, and that I don't believe that Bryce's volumetrics properly read alpha-channel information. But I love your fires, very, verynice! The one on the far right and the second one from the left are my favorites!
AgentSmith ( ) posted Tue, 11 May 2004 at 6:05 PM
Lol, ah, okay. ;o) Thanks, my faves have been (from the left), the 1st and 3rd one. AS
