Mon, Feb 10, 8:28 AM CST
Subject: Newbie question re warping terrains
BlueRose ( ) posted Tue, 25 May 2004 at 3:42 AM · edited Mon, 10 February 2025 at 8:11 AM
i have seen an image of a chessboard which is warped so that it has a slight twist and the corners are folded and twisted over and down a bit. i want to do this in bryce and cannot for the life of me figure it out. Is it possible to do this from within bryce, or do I need another 3D program (that I havent got) to do it for me Many thanks
Ang25 ( ) posted Tue, 25 May 2004 at 7:38 AM
Wings 3D is good and its free, check out the Wings forum for the link to download it. HTH
pogmahone ( ) posted Tue, 25 May 2004 at 7:47 AM
BlueRose - is it possible to provide a link to the type of thing you want to do? That way it'd be easier to say if it's possible in Bryce :o) It sounds like it should be easy enough to do, using a terrain, by a combination of tweaking in Photoshop, and using the Square Edges button in the Terrain Editor (drag to the left to lower the edges). I agree with Ang25, Wings is a great program, well worth learning.
Erlik ( ) posted Tue, 25 May 2004 at 8:10 AM
And with booleaning the terrain in question...
-- erlik
electroglyph ( ) posted Tue, 25 May 2004 at 8:21 AM
You can use a terrain to make the edges curl up. I did the sheets of paper in my Gutenberg render that way. You cannot roll the terrain over itself like you would see on the bottom of a scroll. To do that you have to model.
BlueRose ( ) posted Tue, 25 May 2004 at 3:14 PM
Ive got a picture in a book, i will have to scan it tonite after work (its 8 am ish here) so you can see. Thanks for the help folks!
