Wed, Dec 4, 3:49 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 2:40 pm)
Subject: ATTN: texture mappers
sdmakai73 ( ) posted Tue, 01 June 2004 at 5:08 AM ยท edited Wed, 04 December 2024 at 6:34 AM
I have a model of a gun I've been working on in 3ds max5 and I can't seem to get a good UV map from the OBJ export. Every trick and attempt to cure this problem had failed. I've followed all the tuts and used all the help I recieved in my previous thread. but still no progress. So here's my proposal...If anyone thinks they can get this to work I'll be happy to send you the file to use as you wish...I just need a good qaulity tex to use in my sci-fi renders. Thanks...
hogwarden ( ) posted Tue, 01 June 2004 at 6:07 AM
It might help to address the 'oversmoothing' problem first as whatever the quality of the texture this will always show through... See where all the right-angle sharp edges look messed up in Poser? That's because Poser expects nice organic curvey meshes. To fix this, either add a 'bevel' to each straight edge in Max, or 'split vertices' in UV Mapper... I take it you are using Steve Cox's UVMapper, right?
EnglishBob ( ) posted Tue, 01 June 2004 at 7:01 AM
I agree with hogwarden, a bit of vertex splitting would improve the rendering no end, and UVMapper Pro would probably do a better job of that. I can do that, and UV map it for you, but I'm not the best person to make a texture map. PM me if you want me to take a look at it.
pakled ( ) posted Tue, 01 June 2004 at 9:47 AM
There's a setting on import, 'weld identical vertices'..helps, but I've been there meself..
Lyrra ( ) posted Tue, 01 June 2004 at 3:40 PM
You can also use UVmapper to split vertices to amke nice sharp edges for Poser. After that a simple box map should do the trick
