Mon, Jan 13, 6:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: HELP! Problem with Texture "Kimshara"
RnRWoman ( ) posted Sat, 05 June 2004 at 12:16 AM ยท edited Mon, 13 January 2025 at 5:33 AM
Posted this in another forum but I thought I might find help here too: Hi all; I'm not sure if this is the right forum to post this. But I just bought Kimshara and Kimshara pack 1 at the Marketplace a few days ago. When I load the texture in Poser 4 the default view shows her with a pitch black face, and yet her eye textures are in tact, the body texture loads fine. BUT, when I render her she looks ok. But it's impossible to work on a morph if the texture doesn't look right in the preview. And it loads really slow. Then the program goes nuts sometimes and I lose my mouse pointer. However when I load other hi-res textures like ones from Morris, where they are 4000 x 4000 or so...those textures work just fine. When I load the texture on the figure in Poser 5 it looks fine and no problems. Does anyone else have this problem or know what it is? I'm exhasperated with it. I've tried messing with the Materials and everything... Attached is what it looks like in preview mode in Poser 4. Thanks in advance! God Bless! ~RnRWoman~
Kalypso ( ) posted Sat, 05 June 2004 at 2:03 AM
Site Admin
Yep, had the same problem but I had already been through this with the DAZ Hydra so I knew what was wrong. Take a look at the SIZE of the texture - my system couldn't handle it but when I reduced pixel size down to 75% - 80% of the original it rendered just fine. Of course I have the original backed up for when I upgrade :) Now, imagine having about two characters in a scene, clothed from head to toe, an environment scene and other props, transmapped hair and Global lights. Nice way to melt your pc, eh?
RnRWoman ( ) posted Sat, 05 June 2004 at 2:21 AM
Hey there! Thanks for your reply! Yeah, I tried loading other 4000 x 4000 textures and they seemed to load fine. I even loaded this texture in P5 and it worked fine. I think the texture is only 500 more than 4000 x 4000. So I don't know if it's my PC or what? I suppose I could try reducing the size a lil and see what happens. :) That's a good idea to save the original. :) I have 4 Gigs of RAM (which I think Windows reads 3. something or other of it LOL!), so I'm not sure if it's just Poser 4 or what. But I'll try as you said. My computer is acting up recently with a lot of things. ::sigh:: Yeah! I can imagine even on a fast computer that would really bog the memory down. Thanks again! And I'll go try your suggestion. I hope it works, if not I'm going to do a crazy dance (Just kidding LOL) ~RnRWoman~
Kalypso ( ) posted Sat, 05 June 2004 at 2:34 AM
Site Admin
Don't forget Poser is really bad with memory. Check that you've done these things recently too: emptied Temp, emptied Temp Internet cache, defragged, etc. It should be ok on your system. Also if you've been working with Poser for some time and have loaded a variety of items with large textures and done many renders it's a good idea to restart the computer. I only have 1GB of memory so I get this often with large textures and have to improvise. :( Good luck :)
Tashar59 ( ) posted Sat, 05 June 2004 at 2:48 AM
OK, so I did a test and couldn't get what you have. Size is very possable. I don't want to waist the render so I'll post it. V3 and V2 with both textures at full size. Hope you find the fix.
RnRWoman ( ) posted Sat, 05 June 2004 at 3:37 AM
Kalypso: Yeah, I will try to empty my internet cache out, etc and see how that goes. I'm not sure why it only does it with this texture and only in Poser 4. It's really weird. I tried resizing it and loading the texture but that doesn't work. Unless I should restart Poser 4 after doing so? Sorry to hear you have some trouble with it too. And thanks for your good luck wishes. :) beryld: Thanks for the suggestions. And for the render previews! I'm not sure why this is going on with my comp. But I hope one of the suggestions mentioned will work. God Bless! ~RnRWoman~
Redfern ( ) posted Sat, 05 June 2004 at 5:04 AM ยท edited Sat, 05 June 2004 at 5:06 AM
Forgive me for seeing the humor here, RnRWoman, but your first image reminds me of the Queen of Mars from "Duck Dodgers". But that's a good thing as I find her one sexy 'toon!
Sincerely,
Bill
Message edited on: 06/05/2004 05:05
Message edited on: 06/05/2004 05:06
Tempt the Hand of Fate and it'll give you the "finger"!
DominiqueB ( ) posted Sat, 05 June 2004 at 6:45 AM
Did you install the Memory Updater for systems with more than 1 Gig of Ram for Poser 4 from Curious labs?
Dominique Digital Cats Media
rasputina ( ) posted Sat, 05 June 2004 at 6:59 AM
I had trouble with the texture as well, with the blacked out face, not only that but when it would render it would seem to hang after.
RnRWoman ( ) posted Sat, 05 June 2004 at 7:24 AM
Yeah I've installed the Memory updater many times and it still seems to have problems at times... I've tried other various hi-res textures and they work fine. It's just this one texture. Sorry to hear you're having the same problems, R. :( I did however resize the texture as Kalypso suggested and it now loads properly. Thanks, Kalypso! I wonder why it works in Poser 5 with the old size tho. Redfern: LOL!! A lil humor is needed here. :) Thanks everybody! I wish I could get it to work w/ it's normal size tho :/ Lemme know if any of you find a solution. God Bless! ~RnRWoman~
DominiqueB ( ) posted Sat, 05 June 2004 at 7:51 AM
Out of curiosity you are working in P4 not Pro Pack right? I wonder, since P5 seems to work fine for you if it's not the BUM file bump map (if there is one) that is just too big to handle, bum files contrary to jpgs are notoriously huge. Have you tried rendering it with another character's bump map for the head?
RnRWoman ( ) posted Sat, 05 June 2004 at 12:16 PM
Yep. Just Poser 4 not Pro Pack. I don't think the Kimshara package came with bump maps? I did change the file size down to 3500 x 3500 and it worked. It's weird, I don't understand why it would work on P5 rather than Poser 4. I think perhaps anything above 4000 x 4000 or something to that effect Poser 4 gets confused with and can't use it for the preview. I dunno. Or it could be my PC. Thanks for your inquiries! :) God Bless! ~RnRWoman~
