Wed, Nov 27, 12:50 AM CST
Subject: So close..yet......
CDI ( ) posted Sun, 06 June 2004 at 2:34 PM · edited Wed, 27 November 2024 at 12:36 AM
Oy veh!
Ok...almost got the sun dress workin.
Attached are some caps from my latest sim. The arms are workin now...for the most part.
But if you look at cap 3 youll see my latest hurdle. Why is the dress sticking to her arm like that and can it be corrected???
TrekkieGrrrl ( ) posted Sun, 06 June 2004 at 3:01 PM
It could be a grouping error of some sort. It can also be a jp issue, but my first guess is it has something to do with the grouping. It can be fixed by regrouping that part of the dress. (if it IS a grouping problem)
CDI ( ) posted Sun, 06 June 2004 at 3:04 PM
LOL Its a dynamic cloth. Theres no groups. Unless you mean a material group.
TrekkieGrrrl ( ) posted Sun, 06 June 2004 at 4:23 PM
Oh.. In that case I don't know. I've never tried making dynamic dresses.
CDI ( ) posted Sun, 06 June 2004 at 4:30 PM
LOL Neither have I!! LMAO Thankee though for the suggestion. I would have agreed if itd been a conformer. LOL
TrekkieGrrrl ( ) posted Sun, 06 June 2004 at 4:32 PM
Hmm could it be that those parts intersects at the starting pose? And then goes wonky like dynamic hair sometimes does with self collision turned on?
CDI ( ) posted Sun, 06 June 2004 at 4:39 PM
LOL Well usually if theres intersection at the starting pose, the sim will fail (IE the calculation numbers will just keep changing over and over again and nothign will happen). This "stickiness" happens near the end. As the caps show, it does "let go" near the final few frames, but still it shouldnt be doing that at all. Ive checked the model itself and theres no intersection there. Now in the sim I know her amrs come down close to her body and there could be intersection...but again, if there is, the sim should fail. ...Shouldnt it? LMAO
xantor ( ) posted Sun, 06 June 2004 at 4:48 PM
Is this not just the dress moving up as it should and then in 4 it moves back down?
CDI ( ) posted Sun, 06 June 2004 at 4:52 PM
LOL Nope. A couple of frames before Cap 3 where her arms just begin lifting, you can actually see the poly stretched out form the dress to the underside of her arm. Its like at that point the polygon forgets its a part of the dress and thinks its part of her arm.
Lyrra ( ) posted Sun, 06 June 2004 at 5:45 PM
jww1960 ( ) posted Sun, 06 June 2004 at 6:07 PM
Have you tried setting the "Collision Offset" and "Collision Depth" to lower values? The default is 1 cm. The manual says the minimum value is 0.1 cm. I have found this helps sometimes when cloth is passing between objects. They are found in the "Collide Against..." dialog.
Jeff
CDI ( ) posted Sun, 06 June 2004 at 6:09 PM
LOL Yup. Had it down to .2...Ill give .1 a shot and see what that does.
Dale B ( ) posted Sun, 06 June 2004 at 10:27 PM
Check the relative size of the polys in both the arm and dress section in question. Nerd created some bootie and mitten props to use with charcters interacting with dynamic clothing; it seems that the small, numerous polygons in the hands and feet were small enough that they could violate the collsion detection...at least until they did collide, and the cloth seemed to become trapped -in- the mesh. I think the winding order could have an effect on that as well, but as I am not a modeller, that is just something I remember reading from long ago....
Momcat ( ) posted Mon, 07 June 2004 at 6:53 AM
Do you have any constrained groups? If you have them in that area of the dress under her arms maybe it might cause something like that with that sort of movement.
steveshanks ( ) posted Mon, 07 June 2004 at 1:42 PM
Just a guess here but the stripe across the lower chest is that modeled in or just a material, if its modeled try constraining that part see if it stops the wierd polys, if it does it will at least tell you where the problem is...Steve
diolma ( ) posted Mon, 07 June 2004 at 4:59 PM
I often find that effect occurring when the cloth is approached from both sides. Turning on the "additional cloth collision" options (Object Verts and Object Polys agains cloth) sometimes helps. Also, playing around with the "soft decoration" groups can also help. Another alternative is to adjust the mesh so that the arm-holes (especially around the armpit)are a tad larger (sometimes works, sometimes doesn't). Yet another approach that sometimes works is to save the dress as a .obj at the point where it starts to deform, save the pose, then restart from there. (Although that's probably not a good solution if you are intending to distribute the dress). Just some thoughts. I hope you get it sorted - looks like a nice dress. I'm still experimenting with creating dynamic cloth myself. My general approach tends to be: 1. Create a mesh. 2. Try it. 3. If it fails, experiment with the settings. 4. If that fails, experiment with adjusting the mesh (moving verts). 5. If that fails, experiment with altering the mesh (adding/removing) verts. 6. If that fails, start another design.... Cheers, Diolma
CDI ( ) posted Mon, 07 June 2004 at 7:09 PM
LOL Well I tried several variations of everyones solutions. The one solution I havent checked yet and the one that scares the goofy juice out of me is Dales note about small polys. I havent checked for sure but that area thats sticking is the location of the poly I made as contraint points. Crud. Be my luck thats the issue. Ill keep you guys posted on my work. sigh Diolma: LMAO Jee I hope I get it solved before I reach step 6
