Fri, Feb 7, 5:37 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Poser Newbie
lupus55 ( ) posted Thu, 10 June 2004 at 9:04 AM · edited Fri, 07 February 2025 at 4:09 AM
Hi all, The site is wonderful. I just got Poser 4 and Bryce 5 and am all fired up, and would like to thank all the wonderful people who have put free stuff up to get people started. Now the question. Is it possible to get something I have created in Bryce into Poser 4 as a prop? I have worked out how to import Poser stuff into bryce, but not the other way around. If this is not possible, do I have to break the budget once again to purchase another package to make my props? If someone gives me an answer and I get anything semi-decent knocked up I will then immediately figure out how to get it uploaded into the freestuff area. Cheers
randym77 ( ) posted Thu, 10 June 2004 at 9:19 AM
As I understand it, stuff created in Bryce can only be used in Bryce. You can upload what you've made into the "Bryce" area of free stuff, for other Bryce users to download. As for modelling props for Poser...there's free software you can use. Wings3D and Anim8or, for example.
Kristta ( ) posted Thu, 10 June 2004 at 9:23 AM
Oh, I want to know the answer to this one too! Kristta
lupus55 ( ) posted Thu, 10 June 2004 at 9:27 AM
OK. Thanks for that randym77. I have just dug around a bit more and it seems that Bryce will only export terrains and lattices. Hmmm. Gets more confusing. I will have a look at Wings3D and Anim8or. Grrr Learning Curve seems pretty steep, oh well, time to get serious. Thanks again.
pakled ( ) posted Thu, 10 June 2004 at 9:33 AM
Attached Link: http://www.wings3d.com
As said above, only terrains and lattices..most people are going in the other direction. You can export Poser characters to Bryce..along with clothes and hair (as long as they're not 'dynamic'..;)..at least that's been my experience. There's also a program called Grouper, that will let you assign materials for a character (unless you *like* assigning a mat to 'pinky, 3rd digit'..etc..;) and import into Bryce. And though people are probably thinking of me as the Wingdy's Unofficial Spokesperson..here's where to get wings..
LeeEvans ( ) posted Thu, 10 June 2004 at 11:46 AM
Actually... as long as what you make is not boolean... you CAN export from Bryce... if you select an object, and click the little "E" (the smoothing option) you can hold Ctrl+D and export... :) This will not work for boolean objects tho
dan whiteside ( ) posted Thu, 10 June 2004 at 1:41 PM
Attached Link: http://www.castironflamingo.com/tutorial/grouper/
Yes- Groupers a "must have" for going from Poser to Bryce (link). The Control+D export option only works with imported meshes and Bryce rocks. This way also won't have any Bryce textures applied. There's no way to export any of the Bryce primitives. I sure wish there was! Best; Dan
Ben_Dover ( ) posted Thu, 10 June 2004 at 11:31 PM
Attached Link: http://www.iaw.on.ca/~jspirko/models.htm
You can however download other folk's primitives for Bryce and, providing it's acceptable, make a model and export that. It depends on the terms of use, just have to read the readme's and see which allow redistribution and/or commercial use. I'm fairly sure I saw some here in the Bryce freestuff, you can also find some presets at the link I've posted. Follow the "presets" link at the top on that page. I'm not sure about the usage restrictions though, the readme's are vague about it.
nomuse ( ) posted Fri, 11 June 2004 at 12:44 PM
Umm...my memory is that Bryce also will not export a group. So even if you use third-party primitives, you can't do much towards exporting a complete model.
dan whiteside ( ) posted Fri, 11 June 2004 at 2:24 PM
You're right, Bryce didn't always export mesh groups. I think it started working with Bryce 5, just tired it and it seemed to work fine. Best; Dan
melanie ( ) posted Fri, 11 June 2004 at 7:23 PM
I think if you use the symmetric lattice object in the terrain editor to create shapes of objects, you can export those. It's been a long time since I've tried this, but if memory serves me right, it can be done. Melanie
lupus55 ( ) posted Sat, 12 June 2004 at 2:14 AM
Thank you to everyone for all their helpful advice. When I finally get my head around this wonderfully confusing piece of software and get something that I am not too ashamed of, I will post, and similarly once I can knock up a not too shabby prop, it will go into the free-stuff area. Pity about not being able to import export straight from Bryce to Poser, it would be a marriage made in heaven. Lupus55 ... The wolf not the disease, by the way.
