Fri, Nov 15, 6:45 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: scetch designer problem
peevee ( ) posted Mon, 14 June 2004 at 6:29 AM · edited Fri, 15 November 2024 at 6:33 PM
Hi there, How do you save an image created with the scetch designer? Any thoughts, just post them Thanks Peevee
semidieu ( ) posted Mon, 14 June 2004 at 7:10 AM
Just do... File --> Export --> Image file...
peevee ( ) posted Mon, 14 June 2004 at 10:54 AM
Hm, In fact I ment how do I get the image from the sketch designer in the normal render window (but i figured it out yet.) The reason I ask tghis is because I want to create a money-style image ( the same result as if I scanned a bill ) this is how close I get but it's not there yet... If any one has hints, tips or sugestions to make this look more like a moneyprint ( do not pay attention to the theme of the image, it's only the style I'm interested in ) than post them here please thanks Peevee
TrekkieGrrrl ( ) posted Mon, 14 June 2004 at 2:32 PM
If I understand you right, you're going for the engraved look? Try playing with the lights, they have a HUGE impact on Sketch renders. You can use the Cartoon-with-lines display mode to determine the shadows before sketching.
peevee ( ) posted Mon, 14 June 2004 at 4:11 PM
Thanks for the help, but it's kind of vital to keep the textures ( and the cartoon-with-lines display doesn't keep the textures ) The engraved look ( very fine engravings thow ) is indeed what I'm looking for. In fact there is a much finer technique called "hot neadle" to get the result I want. Carving with a hot neadle into a very hard kind of wax or plastic. Peevee
TrekkieGrrrl ( ) posted Mon, 14 June 2004 at 4:29 PM
No no I meant you could use the Cartoon-with-lines BEFORE you sketched it, as an aid to see where the shadows would fall. You should change to normal textured view before you hit "sketch"
xantor ( ) posted Mon, 14 June 2004 at 5:55 PM
this isnt answering the question but you dont have to use a poser render in the sketch designer you can load any picture as a backdrop and sketch it. I should know the answer to this (I have been using poser since version 1) but can you make animations using the sketch designer?
3-DArena ( ) posted Mon, 14 June 2004 at 6:40 PM
WEll you asked 2 questions - the first how to save. When yo want to creaete a large image you choose the sketch design you want, then you choose to render as an animation - 1 frame the size you want and it will render the pic to disk for you. As for styles, It's kind of pick and choose fo me - I have used Ironbear's presetsat 3-D Arena, I have some there too, but I don't really do the style you are looking for - perhaps 'bears has that - haven't used it in a while. Too I always render several different lighting and sketches then I overlay them i post to get the look I want.
3-D Arena | Instagram | Facebook
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use.
-Galileo
Little_Dragon ( ) posted Tue, 15 June 2004 at 12:10 AM
Yes, you can make animations. In the Make Movie panel, choose Sketch Renderer for Quality, instead of Current Display or Current Render Settings.
xantor ( ) posted Tue, 15 June 2004 at 3:16 AM
thank you.
