Forum Moderators: Lobo3433
3D Modeling F.A.Q (Last Updated: 2025 Feb 13 4:12 am)
Blender | Trimble Sketchup | Wings 3D | Anim8or | Metasequoia | Clara IO (Browser-based 3d modeler)
Check out the MarketPlace Wishing Well, as a content creator's resource for your next project.
The "group" command in the set-up room does a poor job at guessing. It's like those auto-tune buttons on car radios; good for finding the nearest top-40 station but really poor at helping you tune in to the stations you want to listen to. You would be much better off grouping manually, and rigging manually. The tools are there. The tutorials are available on-line -- many of them at Renderosity either in the tutorials section or referenced in older posts in this forum and others. One thing; in the opinion of most people "slicing the mesh" within Poser itself is a fool's game. Your modelling application is likely to be a better choice. Use Poser for adjusting the joint centers and other parameters only.
do your grouping in your modeller. if you only can assign material groups in your modeller...run it through uvmapper and assign those material groups to plain groups. then, download phibuilder....from roy riggs...you can search for it in poser forum. use that to make your skelegon "tree" for poser and import into poser by importing hierarchy file. should all then work fine for you.
![file_113006.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_113006.jpg)
Hi All. I need some help with poser 5 figure creation,here is my first character an elephant,I went to setup room and used the group command and got rid of all the missing geometry and overlaping geometry but still this annoying no bone sign comes up even though there is nothing i can see to select to add to any groupe,i deleted the no bone from the groupe manager and when my figure was made in the pose room it hat a leg that is seperate from the figure when i try to pose that one leg.can anyone advise me on what to do please. sincerely. khall
