Go to the 'File' menu, skip down to 'Import object', a popup with your files should show up, browse to where you saved your downloaded objects, select either the 3ds or dxf and hit 'Open', Bryce will spend a little time getting things in order and then it should show up in your workspace. Note: some objects may need some smoothing, if that's the case, select the 'E' from the little menu to the right of the object and hit the smooth sphere once, that's usually enough...give your object a material or texture and then render.
Bryce Forum Coordinator....
Sometimes when you import an obj. ...for instance a Poser figure or one with texture maps Bryce will have a pop up asking you to locate the source of the texture. You should have it in the same folder as the object in an image folder.
"The happiness of a man in this life does not consist in the
absence but in the mastery of his passions."
I want to download some objects and models for Bryce 5 but I can't figure out how to convert .3ds and DXF files to something Bryce understands! I've only been at Bryce for a month or so, so you can call me a newb.
