Forum Moderators: RedPhantom
" Kristta, here's a screenshot of the material room with the eyes selected (I assume you're using P5). Does your settings differ in any way? Check that the Texture Strength is at 100% " ernyoka1, that looks like a Bryce render to me, in which case the material room won't do much good I assume.
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
xantor, Will the whole scene render in Poser? I thought about trying that but was a little scared of it. Didn't want to blow it up too bad. What do you save the scene as? jpeg? Will it look like the puppy is standing in the sand? I have lighting trouble too. This was literally my first Poser anything so I am still learning.
I think what xantor means is... render the scene WITHOUT the dog in Bryce. Then save as a BMP or whatever file format. Then use that render as a background in Poser. You won't have the problem with the eyes in Poser.
v2.74
GPU.
Will it look like the puppy is standing in the sand? You can import the render from Bryce as a JPG, and then create a ground plane under the puppy in Poser. Assuming you have Poser 5, you can use Stewer's "mat" material to make the ground transparent, but still recieve shadows. With proper lighting, it would work well.
v2.74
GPU.
the trick is to get the outermost layer of the eyeball transparent (like the first mat in the Glass category), then map the inner parts with another mat or two..(I think) Wolfie's Den has a set of lego mats out there that are very shiny, and fundamental colors..I use lego black for the pupils a lot..if you ctrl+mouse click on the eyball, all parts of the eye will be listed, and you can cycle through them this way. Already left a message on your pic about the 'eye' mat..sorry about all the Bryce stuff, folks, but I'm much better at it than Poser..on a relative scale (Geeps?..;)
I like the screen shot, with the cute puppy, and the blood, slime and more blood materials available. Excuse me now as I fall on the floor laughing my ass off! :O) L Well.. what can I say... I have a broad taste.. I think it's called versatile ;o)
Finally finished this. I tried everything. I tried every suggestion made and and finally......here he is Max...post work in PsP Kristta
