uh..it can be done, but the trick is how it's applied over angles, you can set a mat to only cover things up to x degrees off vertical. I'd go over to Daz, then to the Brycetech tutorials, and there are at least 3 of the most comprehensive tutorials on DTE creation I've seen out there..should be something in there along those lines.
![file_115101.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_115101.jpg)
hi, i want to do a landscape and use a bryce snow texture. in the lower level, the texture is right, but in the higher levels (terrain) the texture is changing into stone texture. but i want the snow texture completely over the whole terrain. what can i do?
