Tue, Feb 18, 10:28 AM CST
Renderosity Forums / Fractals
Welcome to the Fractals Forum
Forum Moderators: msansing
Fractals F.A.Q (Last Updated: 2025 Feb 18 8:05 am)
Subject: Gradient converter
Hubbabub ( ) posted Sat, 03 July 2004 at 5:32 PM · edited Tue, 04 February 2025 at 9:03 PM
Is there a program that converts UGR to MAP and vice versa ? /Hubbabub
tresamie ( ) posted Sat, 03 July 2004 at 8:48 PM
It is my impression that MAP files can be opened in UF with no problem. Perhaps that means that you can just change the extension. It's worth a try with a copy. :)
Fractals will always amaze me!
Hubbabub ( ) posted Mon, 05 July 2004 at 2:09 AM
Yes, UF can open, use and convert MAP files.
I have now tested,
you can't use a UGR file in Chaoscope.
But I think I have maybe found a way around it.
Open the UGR file in a text editor
Select the gradient you want to use
Paste the selected text into a new text file
Name it with the MAP extension
Start up WinFract
Load the new MAP (Colors => Load Color-Map...)
Save the color map (Colors => Write Color-Map...)
/Hubbabub
Wub ( ) posted Mon, 05 July 2004 at 7:55 AM
The format of UGR gradients and MAP files is very different...have you actually tried this? Apophysis can save gradients as MAP files ("Save as Map file..." on the pop-up menu in the Gradient editor).
Hubbabub ( ) posted Mon, 05 July 2004 at 8:14 AM
Yes I tried it, but I think the colors is showing up wrong. Oh, I did know that about Apophysis. Cool. I'm going to try that, Thanks. /Hubbabub
tresamie ( ) posted Tue, 06 July 2004 at 12:06 AM
Thanks for straightening me out on that, Mark. I knew one of my two favorite programs could do that.
