Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Which OS are you using? It may not install under 9 (not sure, I use 8.1 & 8.5). If it's possible find another machine with an ealier OS then 9 and install it their. Then copy the files to zip & move it to your machine. Or, (ugh) install an earlier OS on you machine Or format an extra hard drive (bootable) with an earlier OS & reboot to that disk to do your install.
Mac with OS 9, Raydream Studio 5.5. I'm completely lost on what to do about it.
http://schuetzenpowder.com/sigs.jpg
do you use ram doubbler or anything the same?.. is the installer from the desktop/from the disk?.. when exactly does the error warning came up?.. were did you purchase it from?.. .. you may need to take it back to the shop were you purchased it.. i am not shore on the legistics of the thing but, seing as Metacreations have dump the program in the dead sea.. you are intitled to obtain a new product from another source aslong as you have a registerd serial no.(than all you are doing is replacing a faulty applaication) such palces on the web are hotlinehq.com or Carracho.com were you can search fpr back up files.. The error warning of low memory, maybe an extantion problem which can be fixed with another installer. epsilon class of 00
Well, I've tried and tried to install Raydream Studio for Mac and it will not install. I still get an error 25 (low memory) and have had no luck getting it to work. Any suggestions or should I start thinking about a real 3d program from a real company that supports its products? Sure wish Adobe had a 3d program.
