Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
hey doc, if you click on an object, vertex, edge, or point, and type 'a', it will center on your selection..hope I'm not getting ahead of the class..;) of course, if you have a solution to frame 12..I'm all ears..;) drives me crazy..
Doc...what about using Magnets in Tweak mode? Poser models import into Wings at too small a level for it to work. It's the best feature in WINGS and would make creating morphs easier. Any advice on how to get that to work or would we be forced to scale everything up using SCALE UNIFORM in wings with the TAB Key for numerical input to control the scale up and down?
Hi Teyon,
You can change the size of the "Tweak mode" using the "+" (plus) and "-" (minus) keys.
Also, you can change the type of magnet ... details are in the Wings manual.
I will try to do another tut on making morphs using Wings3D because makin' morphs is very easy when you know "Dr Geep's Magic." ;=]
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Hi Teyon, NO! You DO NOT want to center the object on the origin. DO NOT CHANGE THE ORIGIN ! - Your morph will not work. Use the "A" key ("Aim" function) instead. See Page 14 of this tut. Now, the camera will rotate around the selected item(s). cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
hi and thanks. Yeah, I know about the + and - keys but with the default import from Poser into WINGS, the model is too small for it to be of any use. The Magnet tool won't shrink that much, it simply vanishes after a point. I'll have another look at that post when I get back home, maybe I mis-understood something. Thanks Bunches, -T.
Master Ki? ... Post a pic .......... or 2 or 3. Let's see what ya got. ;=]
*** TOP SECRET *** FOR YOUR EYES ONLY *** ****** DO NOT SHOW THIS TO ANYONE ****** ;=] Actually, you CAN scale the object (up - or down) if you need to - details are on Page 8. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Hi, This is such a silly problem that I'm embarrased to mention it but I hope someone can help. I'm happily slugging along and have imported my head and rubbing my hands getting ready to morph and can't "pan" to get the head down after scaling it bigger with the mouse. Of course it's disappeared off the top of the screen. Yeah, I'm using the "Alt" key. I have the standard Logitech wheel mouse. Nothing special about it. Have used all the buttone for movement in other programs. But can't pan. I "tumble" just fine, scroll larger and smaller with the wheel, have it set as in the screen shots for the tutorial, but when I hit "Alt" plus "center button" which isn't a button but the wheel, nothing happens. I'm so FRUSTRATED! So if I import and scale up in the import dialig box before the import takes place, do I have to do anything after that? I really prefer using the "zoom" to scale up and down when I please but maybe this would be an alternative. Sigh.....
cheers,
dr geep ... :o]
edited 10/5/2019
