Sat, Jan 25, 10:32 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: TransPoser doesn't recognize Poser
jshoot ( ) posted Fri, 30 July 2004 at 7:58 AM · edited Sun, 12 January 2025 at 1:51 AM
Attached Link: http://www.jshoot.ca
when I try to import or open a .pz3 file I get the Carrera config window which includes the correct path to Poser. nevertheless I'm still asked to point to the Poser executable, which I do, but the path request is repeated ad infinitum till I finally just cancel.I've tried reinstalling Poser, but to no avail. This is the PC info: Win XP serv pk 1 Poser 4.03 (Curious Labs) Carrara 3.03 Any suggestions would be appreciated...
Pete_Exxtreme ( ) posted Fri, 30 July 2004 at 4:00 PM
One question (with respect!): Are you sure to have a real version of Poser ? Many full warez version can be found on the WEB, with serial on so on... But as far as i know, TransPoser implements dedicated algorithms that seem to check that it's a real fully licensed version of Poser. Thus, your Poser can be fully usuable on its own, but not with TransPoser if you have this problem. Otherwise drop a mail to Eovia Support who will probably solve the problem. Just my 2 cents....
Patrick_210 ( ) posted Sat, 31 July 2004 at 8:11 AM
You should probably install the Carrara 3.04 patch, don't know if that will help this problem though.
jshoot ( ) posted Sat, 31 July 2004 at 8:22 AM
My thanx to both of you, Pete and Patrick for your help. I'll try both your excellent suggestions and see if a solution can be found... ...jerry
falconperigot ( ) posted Sun, 01 August 2004 at 2:26 AM
When you get the 3.04 patch make sure you do a clean install of Carrara before you install the patch. I've found that this is the only way of solving similar problems.
