Mon, Nov 25, 10:15 PM CST
Subject: help I killed my ground
logansfury ( ) posted Wed, 28 July 2004 at 10:33 PM · edited Mon, 25 November 2024 at 8:48 PM
Hello, I went to hit ctrl+R and accidently hit ctrl+E and now my ground plane is completly invisible and when I go to its properties, the visible option is greyed out and I cant re-enable it. Can anyone help? thank you, Logan
Little_Dragon ( ) posted Wed, 28 July 2004 at 10:46 PM
CTRL-E is "Restore Element".
Try CTRL-G. That's the hotkey to enable/disable the ground plane.
Failing that, try pulling up the Hierarchy Editor and clicking the eye symbol to the left of GROUND.
logansfury ( ) posted Wed, 28 July 2004 at 10:52 PM
Hello Little Dragon :) I forgot to mention in my post that I tried ctrl+G without success. How does one pull up the Hierarchy Editor? The Set Parent button is also greyed out on the properties for the GROUND. (PS in a fit of panic I made a blank scene, enabled ground, applied my ground texture, then saved as PZ3, opened my groundless scene and did a File>Import poser document/item and restored my ground. This is good enough to render but I wanna restore my original ground in the groundless pz3 please) Thank you :) Logan
geep ( ) posted Wed, 28 July 2004 at 11:06 PM
Hi logansfury, You can use the Hierarchy Editor (HE) to hide/unhide body parts and other objects like the GROUND. Here is where you find the HE. [menu] "Window" ---> "Hierarchy Editor" Then ... Just click on the eye symbol next to the part you want to hide or unhide. cheers, dr geep P.S. The graphic (above is excerpt from [ THIS TUTOTIAL>](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1645097) ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
logansfury ( ) posted Wed, 28 July 2004 at 11:41 PM
Thank you, Good Doctor :) Your timing is pretty eerie what with the ebots being kaput (the ebot is dead, long live the ebot...) You gotta panicing-newbie detector running via python script or something? ;) Logan
geep ( ) posted Wed, 28 July 2004 at 11:48 PM
No, not a python script ... it's ... NaySayGuy! He keeps an eye on the new posts for me when that pesky li'l ebot goes on strike. At least he's good for something. ;=] cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
zippy ( ) posted Thu, 29 July 2004 at 11:59 AM
Hey thanks dr geep!!! I had no idea what several of those hierarchy symbols meant. zippy
geep ( ) posted Thu, 29 July 2004 at 12:32 PM
cheers,
dr geep ... :o]
edited 10/5/2019
lesbentley ( ) posted Thu, 29 July 2004 at 2:04 PM
If all else fails, try openind a pz3 that does have ground plain in it, save the ground plain to a props pallet, open the pz3 that does not have the ground, load the ground from the pallet, resave the pz3.
logansfury ( ) posted Thu, 29 July 2004 at 2:10 PM
Hello lesbently :) This is exactly what I considered doing if my gambit of saving a ground only scene as a .pz3 then doing the File>Import Poser doc/item failed. I never did try it when the import did the trick, but based on the success of the .pz3 method Im positive this would have worked :) I love hearing that im starting to think as the people around here do!!! Logan
BekaVal ( ) posted Fri, 30 July 2004 at 6:40 AM
Wanted to kill that darn ground all the time! Cause this ground, while being invisible in renders, drives me nuts because it often blocks vision when I'm setting up a scene. Never knew how to get rid of this. Go trying that CTLR-E or CTLR-G thing now. Thanks for bringing this up, Logan.
lesbentley ( ) posted Mon, 02 August 2004 at 9:10 PM
BekaVal, from what you say I am guessing that what restricts your vision when setting up, is not the ground plain, but rather "Ground Shadows", you can turn them off via the "Display" menu.
BekaVal ( ) posted Tue, 03 August 2004 at 8:50 AM
Thanks a lot, Les! :) It was in fact "Ground Shadows", which was bothering me all the time. Feeling a little slow now, not figuring that out ... Beka
