PJF, Of course it's a low temperature environment, not too sure about your processor staying so cool though, when you're using it ;-) OTHERS, Please be sure to look far enough BACK into the thread if you visit it, because quite a few images where posted. Len.
The wait can be horrific, but the outcome can be worse - pumeco 2006
Pumeco, do you have a website where you work from? It would be a good way to host the final files of Pro-Render and display the images you've posted. Sorry, but paging through a 3-mile long thread just gets tedious after a while. If not, there are quite a few gifted web designers here on Renderosity, such as . . . ahem . . . myself ;)
Based on my experience with Poser 5, I am guessing the pro-render relies heavily on the conjunction between materials and render settings. I've found over the last year that lights mean less than absolutely accurate materials combined with the proper render settings. For instance, I dumped "global" light sets in Poser a long time ago. I've found that proper materials properties go much further in making better renders than the most complex light setups in the world. Most of my work in Poser and Bryce now uses 3 lights, maybe 5.
This looks very interesting. I look forward to the release of Pro-Render. :)
He's added new stuff to the end of that thread he linked to - more render examples and things.
Digital
WasteLanD
Ugh...I'm still the cynic...all i see is Bryce native render effects with tweaking of material settings...which we've ALL been doing since we graduated from mirrored spheres over the ocean... Basically all it sounds like is that this guy has spent a ton of time figuring out exactly what settings produce the best effect...and it seems to me that his comparison renders are the basic Bryce render, WITHOUT any of the comparable render effects turned on... That doesn't sit right with me. Now...I'm fairly certain that most of the people who frequent this forum could sit around for maybe an hour tweaking things, and come up with renders that are equal, if not better, than Pro-Render. Now, i'm also fairly certain that i'm not one of those people...so...yes please.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1822731
Just posted some more stuff for you to rip apart, ...have fun. http://www.renderosity.com/messages.ez?Form.ShowMessage=1822731Message edited on: 08/05/2004 14:32
The final pre-release images from PRO-RENDER are now online, and can be seen at the attached thread:http://www.renderosity.com/messages.ez?Form.ShowMessage=1822731
Message edited on: 08/02/2004 15:38
