Wed, Jan 8, 4:38 AM CST
Subject: Camera
arrow1 ( ) posted Mon, 02 August 2004 at 4:00 PM · edited Tue, 07 January 2025 at 4:39 AM
Is it possible to put my main or any camera inside a tent (circus) and place it at the roof pointing down to the ground? Any tips appreciated.Cheers arrow1
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses.  Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
geep ( ) posted Mon, 02 August 2004 at 7:35 PM
Yup. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 02 August 2004 at 7:42 PM
Hi arrow1, Ok, ok ... maybe *that* answer was just a little bit too brief. It is possible that you could find some helpful info in [ THIS TUTORIAL.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1839126) cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
lesbentley ( ) posted Mon, 02 August 2004 at 8:00 PM
Yes, you can place the main camera anywhere you like. Assuming that the center of the tent is at the at the universe origin, try this. Select the Main Camera, zero all the "Dolly" and "Orbit" dials. Now set "xOrbit" to "-90", this turns the camera to look directly at the ground (if you don't want the camera looking directly down use a smaller number). Now use the "zDolly" dial to raise the camera to the desired hight within the tent. If you are asking how to determin the correct hight for the camera in Poser 4, then I'm afraid I don't know the answer, trial and error is the only thing I can sugest.
TrekkieGrrrl ( ) posted Tue, 03 August 2004 at 4:54 AM
Er.. if you need a camera that looks straight down, why not simply use the TOP camera? you can zoom in with it so that it's inside the tent too. And then you can still use the Main Camera for setting up the scene...
arrow1 ( ) posted Tue, 03 August 2004 at 8:30 AM
Many thanks for all your help.Cheers arrow1
jobcontrol ( ) posted Tue, 03 August 2004 at 12:01 PM
The TOP camera is an orthographic camera, one that doesn't show perspective, that is. That's a very unnatural sight.
TrekkieGrrrl ( ) posted Tue, 03 August 2004 at 1:11 PM
Ah of course. Forgot that... Sorry. Hmm I wonder if you can place the top cam then copy the parameters and paste them onto the main- or aux cam?
jobcontrol ( ) posted Wed, 04 August 2004 at 7:19 AM
Hehehe! I've tried it! I've loaded a simple prop (so I have something to see). Then I switched to the "From Top"-camera I did a CTRL-C Switched to "Main"-camera and ... did a CTRL-V ---> The viewport looked exactly like the "From Front"-camera!!! I think, the copy operation took SOME but not all of the parameters. Now I have a Main-camera which cannot move in y or x-direction :-) Well, after a hearty "NEW" the main-camera was normal again! Phew! Willy
TrekkieGrrrl ( ) posted Wed, 04 August 2004 at 9:32 AM
Hmm so the Main Camera became an ortogonal camera too?! innnnnteresting..... I wonder if that would work the other way around too.... :o)
jobcontrol ( ) posted Wed, 04 August 2004 at 1:57 PM
Well, we men always need a woman to tell us, what to do next ;-) I've tried the same thing the other way around. The result is: The Top-cam now shows perspective - but you cannot change the angle of vision - it is always top-down! That would be almost what arrow1 had in mind. Willy
TrekkieGrrrl ( ) posted Wed, 04 August 2004 at 2:09 PM
Hehe thanks for testing it for me. That's actually an interesting discovery, I think. And... This is called to delegate work ;o)
arrow1 ( ) posted Wed, 04 August 2004 at 4:52 PM
Thank you all for assisting me in this project.I have made a little headway by using the x orbit -"90" and the Z dolly to adjust the height.This seems to work ok.I will post my trial render tonight when I come home from work.I have yet to trial the CRTL-C and CRTL-V method.My main problem was to get some form of lighting into the tent and position a prop so it could be seen.Also the ground was a problem as well.However I just loaded some default stage lights and simple circus prop and I am now in the process of adjusting everything.Cheers arrow1
arrow1 ( ) posted Thu, 05 August 2004 at 6:49 AM
Here is a quick render to show where I am at! Is there a texture around for sawdust for the ground? Cheers Arrow1
arrow1 ( ) posted Thu, 05 August 2004 at 3:56 PM
PS.Forgot to mention.Tent by Helmut Schaub,Coolers Bleaches and Hooters from Ziggies Emporium.All free! Many thanks.I am still trying to figure out the camera height.I seem to either go through the top of the tent or too close to the ground.Any suggestions? Cheers arrow1
jobcontrol ( ) posted Fri, 06 August 2004 at 12:18 PM
Try playing with the "perspective"-setting which is, like, the focal length of the camera. You can achieve an extreme wide angle view with 25mm or a tele view with 125mm. Willy
