Tue, Feb 25, 11:59 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
Carrara Free Stuff here.
Subject: 3d studio max and Carrara question.
mmoir ( ) posted Tue, 03 August 2004 at 3:42 PM · edited Tue, 25 February 2025 at 11:59 AM
I did some work for someone who wants to be able to manipulate the model in 3d Studio max 6. I gave him the model exported from carrara as a .3ds file . The client says he cant open the file in 3d studio max 6. What file formats does Max open. I suggested to try importing the file as opposed to opening the file . Can anyone familiar with Max shed some light on this. It would seem odd that 3d studio can't open or use .3ds files. Mike
todd71 ( ) posted Tue, 03 August 2004 at 4:41 PM
max opens .OBJ format i believe...
mmoir ( ) posted Tue, 03 August 2004 at 8:44 PM
If the guy can't open .3ds files then I will look into .obj and other formats Thanks for your response. Mike
ShawnDriscoll ( ) posted Tue, 03 August 2004 at 9:04 PM
MAC or PC? It could be that Max 6 doesn't like Carrara 3ds files.
Animoottori ( ) posted Wed, 04 August 2004 at 2:25 AM · edited Wed, 04 August 2004 at 2:26 AM
Max should open .3ds. If I remember correctly. I think I used it when sending objects from Rhino to Max. Is your client opening or importing? Maybe it was format that had to be imported.
.obj is also quite widely used format so it should work too.
-Hannu Kulju
Message edited on: 08/04/2004 02:26
Animoottori ( ) posted Wed, 04 August 2004 at 2:41 AM
Sorry. didn't read your post well enough. You mentioned suggesting the import. But called to my buddy and he confirmed that Max opens/imports .3ds atleast from Rhinoceros. -Hannu Kulju
Vidar ( ) posted Wed, 04 August 2004 at 9:16 AM
obj works best,i tested this with max 4 some time ago.
Eagle2358 ( ) posted Wed, 04 August 2004 at 5:05 PM
What about .dxf? I think it's pretty standard.
mmoir ( ) posted Wed, 04 August 2004 at 5:50 PM
Thank you everyone for your comments. Dxf is not an option as he wanted textures to come through to Max. Mike
zandar ( ) posted Wed, 11 August 2004 at 5:33 PM · edited Wed, 11 August 2004 at 5:34 PM
.3ds is not a file format that can be opened directly, it can only be imported. Only .max files can be opened directly. All other formats should be imported, including OBJ, which requires an additional plugin (OBJ2MAX). Max6 can import any .3ds file, regardless of what program it was created in originally, so long as it was exported correctly, and the file doesn't contain errors. You might want to ask him what exactly he gets when he tries to import the file (ie. an error message, a blank scene, or an abrupt program failure). This could better pinpoint the problem.
IMPORTANT NOTE: Also keep in mind that .3ds file fomat has a size limitation of 65535 polygons, vertices or texture coordinates per object. This means if any one object exceeds that amount, your file will be bad, and the import will fail. So, if you have a 3ds file you cannot import, this is usually the cause, and it has nothing to do with Max itself.
Message edited on: 08/11/2004 17:34
mmoir ( ) posted Wed, 11 August 2004 at 5:48 PM
Zandar, I can open the 3ds file in Cinema 4d 6+ as well as amapi 5.15 so the file is okay. Didn't know about the polycount per object though . Thanks for the info. Mike
