Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 29 6:06 am)
You say toMAto and I say toMOTo ... etc. ;=] Is it P4 or P5? ... Only her hairdresser knows for sure. ;=] This insane moment brought to you by ... dr geep <---------- "Where weirdness comes naturally!" ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
With Poser 4: (0) If it is a character, select its BODY. Even if the part indicater shows BODY already, press the 2 key a time or two, to make sure that Poser is looking at the current figure's BODY and not someone else's BODY. (1) Select top menu Object -> Properties. (2) In the resulting dialog box, change the name. Attempt to rename the BODY is diverted into renaming the figure. (3) If it is a prop or hair, omit step (0).
Instead of dealing with "figure 1" "figure 2" etc, how does one rename a figure or prop? And, part 2 of this question is how do you add a customized figure to the library? Thanks to whoever can answer this for me :)
