Sat, Jan 11, 11:38 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: cartoony barbarian again...
brainmuffin ( ) posted Sun, 15 August 2004 at 4:56 PM · edited Fri, 10 January 2025 at 4:33 PM
(Forgot to put the picture in the first time....) Inspired by Litst's dwarf, I decided to model a cartoony character of my own.
This was my firt model using real-time subdivision, and I must say that it was very liberating! It took about 10-12 hours to model this figure. It went very quickly, and it was very easy. I modeled completely on the fly, no real plan. If I needed more detial in an area, I just stuck in a vetex or two. No worrying abot polygons with more than 4 sides, the sub-d will take care of that!
You can see his simple control cage in the bottom pic.
Anyway, let me know what you think of Ahnold here.....
mateo_sancarlos ( ) posted Sun, 15 August 2004 at 8:47 PM
Yes, you did a good job on the gubernator. But maybe you could move the eyes a little farther apart, or he may have to do some serious pummelling!
litst ( ) posted Mon, 16 August 2004 at 5:11 AM
Very nice first attempt ! Mastering the vertex modeller is clearly not a piece of cake even though Carrara 3's VM is much better than the previous versions . One tip : when modelling organic models, it's very rare that you need to crease edges . Often, prefer to use parallel edges, close to each other . That will make a better effect, for example where two muscles meet . Also, don't neglect the power of quads ! First, if your model shows a nice grid of quads, the surface will be nicely smooth . And second, if you plan to add bones to a model, having polys with more than 4 sides will cause the subdivision to change when you move the bones . At least, that's the case in other softwares, not sure for Carrara ... Anyway, keep going with the VM ! :-) litst
Vidar ( ) posted Mon, 16 August 2004 at 5:38 AM
cool model and good modeling,you should take a look at edgeloops if you plan to animate the guy.try to keep all quads if possible for better and smoother animation.anyway,this is a great model.:)
brainmuffin ( ) posted Mon, 16 August 2004 at 9:07 AM · edited Mon, 16 August 2004 at 9:08 AM
I would really like him to be all quads, but I fear that in order to do that, I'll have to go in and pick off vertices one by one..... I'm going to see what I can do though.... perhaps I'll play around with the decimation.....
Thanks for the comments, though...
Message edited on: 08/16/2004 09:08
brainmuffin ( ) posted Mon, 16 August 2004 at 9:38 PM
well, I've done some tests, and I've decided not to bust my hump trying to de-triangulate him. I made a couple of simple "figures" and tested them in poser, and I didn't find any problems with the triangulated mesh from carrara. I had problems long ago with the triangulated mesh from ray dream, but it triangulated differently than carrara... I did however, eliminate the creases after I converted to an .obj file. leaving the creases in during the conversion helped though. the creases are much more natural looking now... I'll post another pick as soon as I've got his skeleton set up...
brainmuffin ( ) posted Mon, 16 August 2004 at 9:50 PM
ok, here's a quick pic of the final mesh after converting to an obj.
