Mon, Jan 27, 3:27 AM CST
Subject: How do I fix my scale problem?
pirewyn ( ) posted Fri, 20 August 2004 at 9:16 PM · edited Mon, 27 January 2025 at 3:20 AM
I create 5 wall secions in max. I export them one at a time. wheni import them in poser they import at different sizes from each other. I create one wall section, export it. I reset max, create another wall section scaled to the settings of the first, I export it. Do they import into poser the same size? No. Can someone answer this quandry? It has been a stumbling block for some time and is keeping a really nice product from being available to the 3d community. I can be reached here, or via email pirewyn@yahoo.com
xantor ( ) posted Fri, 20 August 2004 at 10:38 PM
You could load all the wall sections into max and save them as one object, then load them into poser and split them with the grouping tool and resave each part from poser, that way, they will all be the same size.
pirewyn ( ) posted Fri, 20 August 2004 at 10:41 PM
now that is not such a bad idea. . . lemme give it a try
geep ( ) posted Fri, 20 August 2004 at 10:57 PM
Hi pirewyn, What import options are you using? cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
pirewyn ( ) posted Sat, 21 August 2004 at 1:49 AM
Doc, I am importing a 3ds file with the default settings. i didnt think any of those import settings would make a difference. You have a suggestion? The grouping tool routine doesnt work well or neatly as i have got to grap every single face of the mesh in order to avoid having "holes". Is this scale issue fairly common or did i win the prize? It is really t hrowing me, why a door panel made from the cloned parts of a wall panel should be randomly resized by poser when the wall panel was not.
geep ( ) posted Sat, 21 August 2004 at 7:07 AM
Hi pirewyn, If you use the default import settings ... (and it matters not whether you're using P4 or P5 - see above) ... Poser will take the largest dimension (in x, y, or zScale) of the imported object and make it equal to 69.75 inches (using DGS (Dr Geep's Scale for P4 or P5 - PNUs). This may cause your imported objects to be different sizes in Poser. Here's what to do ... 1. Import your object into Poser but ... Make sure you **UNcheck** the **"Percent of standard figure size:"** option. 2. Adjust the Scale of the imported object to the size that you want in Poser. Write down the Percent Value - this is the Scale you will use for all imported objects and then they will be the same relative size as when they were created. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 21 August 2004 at 7:14 AM
Hi pirewyn, Also, you might be interested in [ THIS TUTORIAL.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1620275) cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
pirewyn ( ) posted Sat, 21 August 2004 at 1:33 PM
ok, the grmelins in my computer are very strange and tempermental little creatures. . .theprocess you gave was NOT working and now 5 min later it IS working . . .so after i go bang my head against the wall for about 5 min i am going to FINALLY finish this project. lays laurels at the Docs feet
geep ( ) posted Sat, 21 August 2004 at 2:41 PM
Thanks !!! ... Doc just loves laurels ! (what's a laurel?) ;=] cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
xantor ( ) posted Sat, 21 August 2004 at 4:15 PM
I thought that the parts might have been different sizes and so the "percent of standard figure size" wouldn`t have worked, oh well...
pirewyn ( ) posted Sat, 21 August 2004 at 5:11 PM
Ok here is the set in question. I am not putting it in the freebies as my site tends to get bogged down and geocities tells me to go to hell. . so here is the site . . . www.geocities.com/pirewyn click the castleplay link. . .then go to the dungeon (that is where the d/l are) check out the set and let me know what you think. . i am already working on the second set which should include doors and windows and bit and pieces. cheers, Drew
geep ( ) posted Sat, 21 August 2004 at 5:43 PM
Hi Drew, I went, I saw, I couldn't d/l ... But, I tried. ;=] cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
xantor ( ) posted Sat, 21 August 2004 at 6:09 PM
I got exactly the same error as dr geep.
pirewyn ( ) posted Sat, 21 August 2004 at 7:19 PM
DOH! dammit. . i pay em 5$ a month so that the page will be there. . .grrr
pirewyn ( ) posted Sat, 21 August 2004 at 7:22 PM
seems ok now. . .i mean i told 5 whole people about the dl. . .
