Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Doc, I am importing a 3ds file with the default settings. i didnt think any of those import settings would make a difference. You have a suggestion? The grouping tool routine doesnt work well or neatly as i have got to grap every single face of the mesh in order to avoid having "holes". Is this scale issue fairly common or did i win the prize? It is really t hrowing me, why a door panel made from the cloned parts of a wall panel should be randomly resized by poser when the wall panel was not.
cheers,
dr geep ... :o]
edited 10/5/2019
Ok here is the set in question. I am not putting it in the freebies as my site tends to get bogged down and geocities tells me to go to hell. . so here is the site . . . www.geocities.com/pirewyn click the castleplay link. . .then go to the dungeon (that is where the d/l are) check out the set and let me know what you think. . i am already working on the second set which should include doors and windows and bit and pieces. cheers, Drew
I create 5 wall secions in max. I export them one at a time. wheni import them in poser they import at different sizes from each other. I create one wall section, export it. I reset max, create another wall section scaled to the settings of the first, I export it. Do they import into poser the same size? No. Can someone answer this quandry? It has been a stumbling block for some time and is keeping a really nice product from being available to the 3d community. I can be reached here, or via email pirewyn@yahoo.com
