Mon, Jan 13, 11:48 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 13 3:34 pm)
Subject: mapping problems
voodooninjax ( ) posted Wed, 08 November 2000 at 12:43 AM ยท edited Mon, 13 January 2025 at 5:38 PM
I need some help remapping an obj file. It is a skateboard I got from 3D cafe as a 3ds and converted it. I took it into UVMapper, and it will not work for me, it loads up and the texture map is from the front view. I need all of the faces for the model, and I just can't do it. I want a map something like zygote's skateboard. What an I doing wrong? Please someone help me. Thanks in advance, Voodoo
JeffH ( ) posted Wed, 08 November 2000 at 12:52 AM
Create a new UVmap Planar and try it from X Y and Z..experiment.
voodooninjax ( ) posted Wed, 08 November 2000 at 1:05 AM
Thanks but UVMApper freezes when I do that Jeff, besises, I need to see all the faces, like the zygote example above. Any other ideas man? Anyone? How do they rip it apart like that?
bloodsong ( ) posted Wed, 08 November 2000 at 8:49 AM
heyas; they have a big expensive mapping proggie ;) but you can do something farily simple like a skateboard just fine. try selecting by group (if the different peices are different groups) or material. you can give the board part a box map, for example, to get all six sides laid out. then give the wheels each a cylindrical cap, which will unroll the edge and show the front/back flat. if uvmapper is locking up on you, you have a problem, obviously. try running it with nothing else running, or reinstalling it. if it still locks up consitently for you, better contact steve cox about it.
Steve Cox ( ) posted Wed, 08 November 2000 at 11:12 AM
The skateboard from Zygote (texture template pictured above) was done by Robert E. Whisenant who uses UVMapper to do his mapping =) You can see the entire template here: http://store.zygote.com/PoserTemplates/access/skateboardT.jpg I'm really interested in seeing any model that causes a problem with UVMapper. Could you send it to me at stevecox@optonline.net What did you use to convert the .3ds file to .obj? Also, do you have the latest version of UVMapper? You can get it here: http://www.uvmapper.com Thanks.
Steve Cox ( ) posted Wed, 08 November 2000 at 11:47 AM
I grabbed the skateboard from 3D Cafe, converted it to wavefront (obj) using 3D Exploration (v.1.2.54) loaded it into UVMapper and created the following map. This is just a quick job, there's much more that can be done... Steve
voodooninjax ( ) posted Thu, 09 November 2000 at 2:31 AM
Well I guess I'm just a dumba$$, Steve. I have the latest version of your great prog. Maybe my converter is bad? Can you help me out on how to do what you did? A tutorial perhaps? Thanks in advance, Jason (Voodoo)
Steve Cox ( ) posted Thu, 09 November 2000 at 11:15 PM
Attached Link: http://www.uvmapper.com
Please take a look at my site, I've got several tutorials there. You can find it at either: http://home.pb.net/~stevecox http://www.uvmapper.com If you have specific questions after looking them over, let me know and I'll do what I can to help. good luck, Steve
