Mon, Dec 23, 5:10 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Dec 19 7:58 pm)
Subject: Multiple Lights Problem
aodor ( ) posted Wed, 25 August 2004 at 7:20 PM · edited Mon, 23 December 2024 at 11:21 AM
If I set a scene (DAZ Studio 39)with the light setup provided with the pack, every time I click on one of the viewports, lights turn off or on depending on what item I click. All Lights have de visibility attribute to ON. How can I make D|S to keep all lights on all the time? Alberto Odor, MD Mexico City
casey_42 ( ) posted Thu, 26 August 2004 at 2:44 AM
It sounds like your problem is not the lights but the cameras, possibly some of the cameras are looking at the outside of a wall that is out side of the ighted area, try moving the cameras closer to the center of the scene and see if that clears up the problem. Casey_42, the Old Newbie
RHaseltine ( ) posted Thu, 26 August 2004 at 9:29 AM
Online Now!
Generally, Poser lights do not work well in D|S - the approach is very different. Poser 5 using the Firefly render is similar, I believe, though P5 doesn't have point lights as D|S does.
aodor ( ) posted Thu, 26 August 2004 at 9:41 AM
I'll try moving the camera and/or replacing the lights. Thank you for your answers.
casey_42 ( ) posted Fri, 27 August 2004 at 8:33 AM
Generally when I import a scene from poser that includes lights and cameras the first thing I do is delete all the camers and a lot of times all the lights, the native cams in D|S are usually sufficient for anything I desire to do even though deleting the cams means I have to create a new default camera so I can tie a spotlight to it to act like a flash if I want one, and so I can control it with the dials. Casey_42, the Old Newbie
aodor ( ) posted Fri, 27 August 2004 at 8:59 AM
Thanks Casey, that's a nice tip, Ill trai it.
casey_42 ( ) posted Sat, 28 August 2004 at 8:19 AM
You are very welcome and I hope it works well for you, I assume you have found out that all lights need to be set at less than 100% illumination or your renders will be washed out. Casey_42, the Old Newbie EZ Duz it
