Thu, Nov 28, 5:20 AM CST
Subject: Still on a Rope quest...
bandolin ( ) posted Mon, 30 August 2004 at 8:02 AM ยท edited Thu, 28 November 2024 at 5:20 AM
Someone gave me a great method for creating a rope. Take 3 metaballs, arrange them in a circle, and multi-replicate them with a 10 rotation the the desired length. It make for a great realistic rope. Unfortunately, it also makes for an enormous polygon count. I'm building a 17th century sailing ship, and I've got miles of rope to make. I'm not even 10% done and my machine is already choking. Anyone, know of a texture that can be applied to a simple cylinder or torus, that looks like realistic rope? I'm new at Bryce, haven't got the hang of making textures. Bandolin PS: I'll soon be tackling the sails. If anyone has any ideas about sail canvas, I'd appreciate it. Are they made from terrains?
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
TheBryster ( ) posted Mon, 30 August 2004 at 8:20 AM
Forum Moderator
I think there is a rope texture or two in the freebies section......look under 'materials'
bandolin ( ) posted Mon, 30 August 2004 at 9:07 AM
I've raided the freebie section of everthing I could find useful. There was no rope texture there, as far as I could see.
<br />
Freestuff</a>
Ornlu ( ) posted Mon, 30 August 2004 at 9:16 AM
Yeah, if you're going to be far away in the render. you can just use cylanders. if you need it to hang just multi rep them almost the full length of the cyl then rotate slightly.
TheBryster ( ) posted Mon, 30 August 2004 at 9:28 AM
Forum Moderator
Bandolin: I just looked myself. Sorry, but it doesn't seem to be there.....:-(
electroglyph ( ) posted Mon, 30 August 2004 at 10:02 AM
Apply this to the bump channel parametrically. It should do the trick.
bandolin ( ) posted Mon, 30 August 2004 at 11:27 AM
Thanks electroglyph, it looks really cool. Sorry for being such a dufus newbie, but how do I apply this to the bump channel exactly? Bandolin
<br />
Freestuff</a>
bandolin ( ) posted Mon, 30 August 2004 at 11:58 AM
Ok, forget my last post. I figured out how to add a 2D pic in the texture editor. Stupid me, I forgot the tutorial showed exactly how to do it. Unfortunetly it still doesn't achieve the effect I'm looking for;
<br />
Freestuff</a>
electroglyph ( ) posted Mon, 30 August 2004 at 12:23 PM
Save the image file on your hard drive in a place you can remember. Create your rope object then click on the M as shown.
electroglyph ( ) posted Mon, 30 August 2004 at 12:27 PM
When The materials lab opens: 1 click on the A button next to the bump channel A default random DTE texture will appear to the right side. 2 click on the P button to change to a picture texture and make leo appear. 3 click on the pinkish button above this to open the picture editor window.
electroglyph ( ) posted Mon, 30 August 2004 at 12:33 PM
When the pictures window opens: 1 click on any empty gray square to load a new texture. If the box is already occupied you will load the new texture over the old one. A windows dialog box will open up. Browse to the location you saved the picture texture and select the filename you saved it as. 2-3 Once the image appears click copy under the first window and click paste under the second window. Transparency and bump have to be loaded into the second window to do anything. When the window that says "Are you sure you want to delete?" pops up press "delete". 4 click on the check to exit.
electroglyph ( ) posted Mon, 30 August 2004 at 12:40 PM
The size of your texture will be different depending on the mesh size. To change the size of your texture press M on the selected object again. When the materials window pops up again: 1 press the green button to bring up the edit texture window. 2 grab in the center of the 6 way cross object and all three scales X, Y, and Z will change at the same time. A good place to start this texture is around -5 for each of these. If the spiral is too steep you can change the Y individually. Unfortunately you will just have to play to get this to work for you.
RodsArt ( ) posted Mon, 30 August 2004 at 3:36 PM
Here is a revamp of your rope with the settings for a cylinder that has the length extended, a little tweaking with these settings will give you a decent looking rope...I Hope. ;)
___
Ockham's razor- It's that simple
RodsArt ( ) posted Mon, 30 August 2004 at 3:38 PM ยท edited Mon, 30 August 2004 at 3:40 PM
Here are the settings. The longer the mesh or cylinder...You'll have to tweak these numbers.
Message edited on: 08/30/2004 15:40
___
bandolin ( ) posted Tue, 31 August 2004 at 9:09 AM
You are a god! Tried it out, it works like a charm Many thanx Bandolin
<br />
Freestuff</a>
