Mon, Jan 27, 10:19 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Ground Level Adjustment: What's the Secret?
moushie ( ) posted Mon, 30 August 2004 at 12:16 AM ยท edited Sun, 26 January 2025 at 9:43 PM
Ive asked this before, without luck. Maybe this time Ill be lucky. I save a walk pose in the library. When I load it onto a figure, the figures feet float above ground. I methodically click Ctr/D for ground level at each frame. But on playback the figure walks steadily into the ground, its knees buckling, like a clown act. Whats the solution?
Rance01 ( ) posted Mon, 30 August 2004 at 5:07 PM
IK maybe? Try turning off IK. You might also translate the figure BODY as well, rather than using Ctr/D. Poses use the figures hips rather than BODY. If you translate the body at frame number one you should be in good shape. Rance
moushie ( ) posted Mon, 30 August 2004 at 6:30 PM
It's not IK. And usually the first frame is OK: it's the frames added by the walk libary that are sunken or in the air. Phil C has now shown me how to adjust any number of (hip y tran) frames en bloc, without losing the ups and downs of walking -- and all with one action. Thanks for your input.
