Wed, Feb 12, 3:38 AM CST
Subject: Animate textures?
oral-b ( ) posted Tue, 31 August 2004 at 2:32 PM · edited Sat, 08 February 2025 at 11:37 PM
Is it posible to use animated textures in Bryce.I need to use a secvence of 3 pictures.The total nr. of frames in the Bryce render will be 3, an i want the object to have diffrent tex in all 3.Humm... that was much ado about nothing!
draculaz ( ) posted Tue, 31 August 2004 at 3:09 PM
i think you might be able to do that through the deep animation editor, although i'm not entirely sure how. i do know that you can change an object in an animation and make it have different textures throughout
Aldaron ( ) posted Tue, 31 August 2004 at 4:35 PM
Textures can be animated though I think 3 frames will be too little to actually see anything(ie too fast). Do you want the textures to merge one into the other or just abrutly change like a slide show? Pure and simple way is go into the material editor for the object. At the bottom are animation controls, move to the frame you want and change the texture. How it behaves depends on what you want from my question above. Also before animating any textures save a clean file to put away. Once textures are animated they are very difficult to remove the animation....it's been a long time since I've done any of this stuff, think I have it right.
Mahray ( ) posted Tue, 31 August 2004 at 7:10 PM
In the texture editor, set first texture - keyframe. Move the slider to the frame you want the next texture to finish on, set texture - keyframe. Repeat. I've had it work in turning a statue into a demonic beast. Just don't forget to keyframe!! (You might also want to turn autokey off if it irritates you).
Come visit us at RenderGods.
Ignore the shooty dog thing.
oral-b ( ) posted Tue, 31 August 2004 at 9:48 PM
I`m going to make static noise on a TV. Thanks for the help
electroglyph ( ) posted Wed, 01 September 2004 at 8:44 AM · edited Wed, 01 September 2004 at 8:45 AM
If you have keyframes in between the texture will morph from one setting to the next and blend. If you want sudden changes you change the texture every frame and add a keyframe for each.
An example is a starwars logo thing I did. I made the text yellow and added an initial keyframe. I made it transparent moved it to the other side of the screen and added another keyframe at 1 minute. The texture started fading from frame 1 until I added another yellow keyframe at 55 seconds. Then it stayed yellow for 55 seconds and faded over the last 5.
I would select a bumpy sand texture in the DTE and change the colors to white, gray, black. apply this material to the first keyframe. move to the last keyframe and apply an offset in the direction perpendicular to the TV Screen of more than your total keyframes. If you are doing 15 frames per second and you have a 3 second animation that will be 45 frames. If your offset is Z 45 or greater you will have a different texture for each frame and will not have to worry about creating a new image for each frame.
Message edited on: 09/01/2004 08:45
electroglyph ( ) posted Wed, 01 September 2004 at 1:36 PM
If you really only have three frames it might be easier to load an image texture. Load three image textures into three seperate texture locations. Don't load the texture on top of the same square it will erase the first texture. Click the keyframe while in the texture window. Once you are back in the main bryce wireframe those keyframes only affect motion.
electroglyph ( ) posted Wed, 01 September 2004 at 3:54 PM
Is this what you are talking about?
electroglyph ( ) posted Wed, 01 September 2004 at 4:42 PM
You have to load each image seperately and use one for each keyframe. I made my textures by creating 100% noise on a 100x100 square in PSP I grayscaled then copied. I pasted the image onto a 50x50 square and shifted the location each time saving three as snow1, snow2, snow3. I loaded each image into the materials in a seperate box.
electroglyph ( ) posted Wed, 01 September 2004 at 4:48 PM
I got this TV from 3dcafe. I clicked on the screen and went into the materials editor. There I loaded snow one into the materials. Parametric was awful so I used object front. I used the animation window in the materials lab and pressed + to set the keyframe. I moved the slider to the second frame and loaded snow2 set another Keyframe and etc for the third image. I rendered the three images out as bitmaps and created the gif image above in animation master that comes with paintshop.
