Attached Link: http://www.java.com/en/index.jsp
Microsoft anounced some time back that the Virtual Machine (what allowed Windoze to view java) is no longer supported. It has to do with a falling out between Sun MicorSystems and Microsoft. The code never actually belonged to MS. In order for Windows OS to continue to utilize Java based applications you must switch to the Sun System's 'Java Console'. Read details here: http://www.microsoft.com/mscorp/java/ and here: http://www.microsoft.com/presspass/press/2004/apr04/04-02SunAgreementPR.asp Get Java here (note: Microsoft will NOT support any issues that may arise and Sun Systems is responsable for All security issues): http://www.java.com/en/index.jspI can open the zip file, extract most of the files except the texture.bmp, it's corrupted. In WinZip I do get this: Extracting texture.bmp Error: unexpected end of file encountered Error: invalid compressed data to inflate Tried downloading the zip files a couple of times, but with the same result eacht time.
Food for thought.....
Just downloaded it and it opened fine for me. The only thing I had to do was use edit pad to change the texture.bmp that the pp2 called for - to the texture.jpg that is included in the zip file. You might want to do that before you load it into poser and get the can't find message. Nice F16, thank you for sharing it. :-)
I just downloaded it and everything opened fine for me. I have W98 se. May I ask a dumb ??? Do I put the files in my props library or figure library? Thank you!!!!!!!!!!! I love it, zoommmmmmmmmmmm
Much thanks - As someone who once tore these jets apart in RL, I'd like to beat up on the texture a bit... I'll post the results if I can get time to actually do it.
Also, I'll see if I can't set up some smart props to tack noto it for the missing parts (wingtip rails, upper UHF antenna, etc.) as well as some optional parts (external fuel tanks, EW pods, etc.)
/P
Message edited on: 09/03/2004 10:58
Attached Link: http://www.dutchman3d.com
Go to Download page.
