Sun, Feb 9, 11:23 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: Re: Sponza Atrium Lighting
adolphin2000 ( ) posted Sun, 05 September 2004 at 5:17 AM · edited Sun, 09 February 2025 at 10:20 AM
I've been looking at this weblink:
http://hdri.cgtechniques.com/~sibenik2/
the Sponza Atrium part of the website, which I'm sure most of you already know about. You can download the model in various 3d formats and then play around with various lighting settings.
I'm really interested to know whether any Carrara users have attempted to light the Sponza atrium scene, and hear from people who have used various techniques of lighting. Whether that be HDRI alone, and the careful placement of lights in the scene.
I've played around a little myself, but would be good to hear from some of our more experienced users here, as well as some of our less experienced users too.
If you have already rendered this scene in the past, I'd certainly like to see your images! (of course only if you're happy to post them as examples.)
I feel quite confident that Carrara is capable of rendering this scene just as good as those more expensive apps.
goofball ( ) posted Sun, 05 September 2004 at 2:58 PM
http://www.renderosity.com/viewed.ez?galleryid=557833&Start=1&Artist=goofball&ByArtist=Yes I did this scene in Carrara with only HDRI lighting. I think it competes with some of the other renders.
adolphin2000 ( ) posted Sun, 05 September 2004 at 5:09 PM · edited Sun, 05 September 2004 at 5:10 PM
I see what you mean about competing with the other more expensive 'packages'. Did you use an HDRI image mainly made up of 'sky', or was it an image which contained other details in it?
Message edited on: 09/05/2004 17:10
bluetone ( ) posted Sun, 05 September 2004 at 9:30 PM
Your image is great! Now you've got me hooked! Downloaded all the models and lets see how soon I can start cranking out some images! I'll let you now how it goes. :D
MarkBremmer ( ) posted Sun, 05 September 2004 at 10:23 PM
Yes, this is a fun one to play with. I've worked on several time-of-day images -- here's one. No HDRI but I did use indirect lighting set to 300%. One "sunlight" spot and another for ambiant fill. The regular ambiant is set to zero. The background is a .jpg version of the Snowfield by Sachform, used as a map.
goofball ( ) posted Sun, 05 September 2004 at 10:41 PM
It was an HDRI map of a city, containing everything from the sky to the road. I cranked up the intensity I don't remember to what but it was high.
ayodejiosokoya ( ) posted Mon, 06 September 2004 at 12:15 PM
This looks cool. I am going to have to give this a go at some point.
FWTempest ( ) posted Mon, 06 September 2004 at 3:41 PM
here's one that I've been playing with... was trying to light the thing using only GI, and was pleased with the way the render was turning out, until it got to that extremely dark shadow at the bottom of the far wall. Any suggestions to get rid of that? I've included my render settings. Background is simply a blue color sampled from the supplied sky.jpg... texture on the model is the pale pinkish/orange that you can see with no bump or reflection and slight highlight. No other lights were used.
MarkBremmer ( ) posted Mon, 06 September 2004 at 3:44 PM
FWTempsest, The darkness should go away if you select either Full Raytracing, uncheck interopolation or both. Mark
FWTempest ( ) posted Mon, 06 September 2004 at 3:48 PM
Mark... full raytracing is selected and interpolation is off...
MarkBremmer ( ) posted Mon, 06 September 2004 at 4:01 PM
Duh! I should completly read your first post before responding! Well that is exciting then. Increasing the photon count will probably help - but it may start driving the render time up longer than you'd like. However, there are two other things that I would try: 1) select the geometry in the vertex modeler (you'll need to convert it first) and crease the whole object to make sure Carrara understands that it's a completly flat surface, or 2) place a cube behind the far wall and allow it to intersect the wall slightly to prevent any "light creep" that may be occuring at the corner.
rendererer ( ) posted Mon, 06 September 2004 at 4:54 PM
Speaking of which, what is the difference between "full raytracing" and not full raytracing?
MarkBremmer ( ) posted Mon, 06 September 2004 at 5:11 PM
Selecting Full Raytracing doesn't allow Carrara to "cheat" and save time while it's doing it's calculations. Using Full Raytracing forces Carrara to calculate the full path (4, 8 or whatever raytracing options you have set)of all rays instead of thinking, "these two light paths are similar so I'll only figure for one of them". Likewise, Interpolation for global illumination does something similar. Since doing the complete calculations for global illumination is very complex (takes time), interpolation accuracy simply tells Carrara how much "educated guessing" to do resutling in saved time. The default is 20% percent accuracy which is a bunch of guess work. That's why some renderings look so blocky - the guess was inaccurate. Eliminating or reducing the interpolation plus forcing Carrara to calculate all of the light rays gives a better result - but it will result in an increase in render time. Mark
rendererer ( ) posted Mon, 06 September 2004 at 6:37 PM
Thanks, Mark, for the reply. I wish Eovia had included some comparative images on the Carrara CD to show how these options affect image quality and render time. Maybe if I'm feeling industrious one of these days I'll put something together for the Carrara community.
ShawnDriscoll ( ) posted Mon, 06 September 2004 at 8:48 PM
The render settings in Carrara are pretty ambiguous. But the manual does mention that rendering with "Improved Edges" checked will reduce the shadows in corners. I've never had to check that option to remove corner shadows (I call them ashes). I will post a render with the settings I'll be using. Right now I'm fixing the objects in the scene that have their texture brightness turned off. I imported the 3DS file after finding their OBJ file a nightmare to work on (it's all one piece).
FWTempest ( ) posted Mon, 06 September 2004 at 10:11 PM
I'm using the 3DS version too... I'm about to go to bed, but I'll check the Improved Edges and start this render again and sleep on it. Maybe that'll do the trick...
ShawnDriscoll ( ) posted Mon, 06 September 2004 at 11:40 PM
I rendered the atrium just now with 5000 photons (I think this is Carrara's default amount). I had ashes everywhere when using the Fast Quality Lighting setting. Using the director's camera, I noticed that the atrium model is pretty small. The diameter of the lens on my rendering camera is as wide as one of side hallways. I resized the atrium about 4-5 times larger and rendered again (with 5000 photons using Fast Quality Lighting). No ashes this time (or just very small ashes, smaller than a penny). Now I'm going to use 30000 photons to lighten up the darkened "cave" areas in the atrium (I probably only need 20000, though) and use Best Quality Lighting for my final render.
FWTempest ( ) posted Tue, 07 September 2004 at 8:10 AM
Ok... this is better... I'd always been afraid of that checkbox with its 'slow' in parenthesis. :) I also resized the model to about 500%... but, and I may be wrong, it has been my experience working on this project that its the intensity setting for the indirect lighting which makes the most impact in lighting those dark corners. This one used 20000 photons, sky light @ 325% and indirect light @ 225%... plus Improved Edges was on for this one. Thanks for all the help and suggestions... I learned a lot about C3 playing with this one. Now, I think I'll give it shot with textures... :)
adolphin2000 ( ) posted Tue, 07 September 2004 at 8:31 AM · edited Tue, 07 September 2004 at 8:32 AM
FWTempest, I'll be looking forward to seeing yours with textures. I assume textures will really bump up the render time. I havn't had much time,(unfortunately) but I will try and get my WIP version up real soon.
Message edited on: 09/07/2004 08:32
FWTempest ( ) posted Tue, 07 September 2004 at 8:38 AM
probably will bump up the render time a bit... especially with some 'bump' thrown in.... ;) This last one was about a 1 hour render @ 900 x 700... which I wasn't too displeased with, at all(of course, I'm used to using Bryce, also, which means waiting around all day for complex renders).
ayodejiosokoya ( ) posted Tue, 07 September 2004 at 12:13 PM
I think once you have textures turned on you can get away with much lower render setings because they mask the ashes quite will. I was wondering how to import the model without the need to crease all of the edges? Also how do you apply textures to this model in Carrara? It look like it will be an absolute nightmare.
mateo_sancarlos ( ) posted Tue, 07 September 2004 at 1:40 PM
That last atrium scene was very good. It's interesting to note how Carrara render times differ from Shade (Curious Labs) in regard to photon count. E.g. a Carrara render with 20,000 might take the same time as a Shade render with 1,500,000. I get the feeling that the two algorithms must define photons differently, and that Shade is undercalculating the effects as compared to Carrara.
ShawnDriscoll ( ) posted Tue, 07 September 2004 at 5:42 PM
I've been using: Ambient Lighting: 0% Sky Light: 570% Using a very light blue background (almost white). Indirect Lighting: 100% Photons: 20000 Best AA 1 pixel, 1 pixel Best Lighting 1 pixel Rendering with no textures, over 7 hours on my PIII-1000Mhz 512MB system. Came out looking perfect. Couldn't save it though (Unknown error occured). With textures & bump, over a day probably.
ayodejiosokoya ( ) posted Wed, 08 September 2004 at 3:37 AM
Shonner which file format are you trying to save in? I have some problems with .tif. If I want Alphas I use .psd. If you are doing a long render it also may be better to render to a file instead of saving after the render.
bluetone ( ) posted Wed, 08 September 2004 at 4:01 AM
I've never had a problem rendering to TIFs on either platform. What problems are you having? And I agree about rendering to a file. If I have a large memory hog, like GI, then I render using the batch queue. Much safer, especially for animations, and more reliable for saving the file. If I'm just doing some tests, then I'm usually not interested in saving the image anyway. Just my 2 cents! :D
sslide24 ( ) posted Thu, 09 September 2004 at 1:35 AM
Shonner You need upgrate your system
ShawnDriscoll ( ) posted Thu, 09 September 2004 at 1:43 AM
Yes. I gave up on the Sponza model. Parts of the floor were missing in the render.
ayodejiosokoya ( ) posted Thu, 09 September 2004 at 12:12 PM
I think once you have textures turned on you can get away with much lower render setings because they mask the ashes quite will. I was wondering how to import the model without the need to crease all of the edges? Also how do you apply textures to this model in Carrara? It looks like it will be an absolute nightmare but you seem to have managed it well..
MarkBremmer ( ) posted Thu, 09 September 2004 at 12:18 PM
I used the .3ds version because of the smaller file size. There are already shading domains on the geomtery and the textures - if you download them from the Sponza site - simply go where they are supposed to. I don't know if the model has been opened without the textures, whether Carrara will "find" them, though. There was one bit of strangness for me. Some of the objects with the textures was pure black. I discovered that for some reason the intensity of the the maps was at zero instead of 100%. I just slide them to where they belonged and everything was fine.
ayodejiosokoya ( ) posted Fri, 10 September 2004 at 5:53 PM
Thanks for the info. I went with the obj file cause I thought that would be the best. I am not sure how far I will go with this though my puny Athlon 850 almost keels over when I crank up the render setting with this model! I need a new cpu baaaaaad.
ayodejiosokoya ( ) posted Mon, 13 September 2004 at 12:25 PM
Here is my attemot. The top render took 12 hours to render at 1500 pixels wide and the bottom took 4 hours to render at 1000 pixels wide on an Athlon 850 512 megs of RAM. Came out quite nicely if I dont mind saying so myself
MarkBremmer ( ) posted Mon, 13 September 2004 at 12:32 PM
Very nice indeed.
ayodejiosokoya ( ) posted Mon, 13 September 2004 at 2:51 PM
Thanks! :) Quite a fun challenge. Rendered with one spot light pointing into the Sponza top and and a light blue skylight if anyone wanted to know.
litst ( ) posted Tue, 14 September 2004 at 7:35 PM
Hi folks, It's very interesting to light this scene, hey ! Not easy, for sure, but there's a lot to learn here ! :-) Too bad you have to dig into every shader to fix the problem Mark was talking about with the intensity of the texture-maps :-( Here's mine, with the render engine settings in french, sorry about that . I got a Distant Light at 150% for the sun and some simple blue in the Environment for the sky . There's no post-render at all except the Carrara DOF, and also the Gamma function of the render engine which was really needed to get things as i wanted them . A render right off the oven, then ! litst
ayodejiosokoya ( ) posted Wed, 15 September 2004 at 2:33 AM
Looking good! The Dof is quite effective in adding depth to the scene.
MarkBremmer ( ) posted Wed, 15 September 2004 at 5:31 AM
Sweet. This is definatly a fun scene to learn and play with.
