I'm doing this the same way. However you might try to add a transparent material like it's used for some parts of the eyeballs when you import a Poser figure.
Haven't tried it myself, but might be worth a try. ;)
But you should save the original mat of the object before you do the change, so you can change it back again.
Message edited on: 09/08/2004 10:07
Is there a simple way temporarily to hide just one object in Vue? The only way I can find is to drag it on to a separate layer that has visibility off, select "render only visible layers", and then drag it back into the previous layer. This is a bit tedious, especially when the object is part of a group. One expects objects to have a visible/invisible property, but this doesn't seem to be the case. I'm working on my first large Vue project, so I hope you don't mind if I bother you with a few more questions like this. Manuals tell you what things do, not what you really need to know. You need to ask experienced people to find that out.
