Mon, Feb 10, 8:21 PM CST
Subject: Hiding a single object
Phantast ( ) posted Wed, 08 September 2004 at 5:07 AM · edited Wed, 05 February 2025 at 6:00 PM
Is there a simple way temporarily to hide just one object in Vue? The only way I can find is to drag it on to a separate layer that has visibility off, select "render only visible layers", and then drag it back into the previous layer. This is a bit tedious, especially when the object is part of a group. One expects objects to have a visible/invisible property, but this doesn't seem to be the case. I'm working on my first large Vue project, so I hope you don't mind if I bother you with a few more questions like this. Manuals tell you what things do, not what you really need to know. You need to ask experienced people to find that out.
TheWingedOne ( ) posted Wed, 08 September 2004 at 10:06 AM · edited Wed, 08 September 2004 at 10:07 AM
I'm doing this the same way. However you might try to add a transparent material like it's used for some parts of the eyeballs when you import a Poser figure.
Haven't tried it myself, but might be worth a try. ;)
But you should save the original mat of the object before you do the change, so you can change it back again.
Message edited on: 09/08/2004 10:07
thomllama ( ) posted Wed, 08 September 2004 at 11:48 AM
from what I undrstand having an obj visable/invisable is a Pro only thing, otherwise you have to keep doing your layer thing. at least that's what I understand.
Hexagon, Carrara, Sculptris, and recently Sketchup.
nanotyrannus ( ) posted Wed, 08 September 2004 at 12:44 PM
Yup, afraid thom is right, this option is Vue Pro only (the option is a right click that says "hide from render"). Sorry, it is a pain to do it using layers.
Phantast ( ) posted Wed, 08 September 2004 at 1:23 PM
Hmm - I hope some of the Vue Pro features filter into Vue 5. This is not the only feature that seems to me to be something that should be a fundamental feature of any rendering app which is "reserved" for Pro. Independent zooming of views is another one.
BGHart ( ) posted Thu, 09 September 2004 at 3:09 AM
Not sure, if I understand you right. But to make an object invisible in Vue 4 I only use the material editor and put the transparency to 100 %. This way you can keep the object in your layer and make it reappear any time you want just by setting the transparency level to "0".
Phantast ( ) posted Thu, 09 September 2004 at 5:01 AM
Unfortunately the object that is giving me problems at the moment has a comples material which I don't want to tamper with more than necessary. But yes, this would be an option, particularly if I save and reload the proper material - actually that might be the easiest.
nanotyrannus ( ) posted Thu, 09 September 2004 at 10:45 AM
One thing to note about that transparency thing, there is currently a bug in Vue 4's volumetric atmospheres (which eon has no good fix for at present) that causes even 100% transparent objects to show up as a ghosted back outline.
