Forum Moderators: RedPhantom
when you download any model (figure, prop, etc), it normally comes in a zip file. Sometimes the creator puts it in an .exe format which installs itself to your poser library. But most of the time it comes in a .zip file. When you extract that .zip file, then open it, you will usually see more folders inside the main folder. Primarily, a folder called Runtime. In order to get a model to work properly inside poser (regardless of what version of poser you're using), the model's files need to be in the propper subfolders of your poser runtime directory. Different files have different extensions and belong in different sub-directories of poser's runtime folder. Once you have all the files for that model in the propper folders, then the model will appear in the library pallet of poser, and all you have to do to import it into your poser scene is double click it, or check the check marks at the bottom of the library pallet (which is actually the correct way). If cassandra is a completely original figure, then the character file (.cr2) for cassandra will refer poser to an object file (.obj) which is the base mesh or geometry of a figure. However, if cassandra is a figure that's based off of another figure's geometry (example, vicky 3), then cassandra's character file will require that you first have the vicky 3 model installed before cassandra can be used.
Ok...now i guess i understand a lot better. ill try this also ill take the model at daz3d. **i downloaded cassandra and cassandra fairy...both was in a .zip file and with a folder runtime. 3 folder int the runtime directory -libraries -readme -texture Thanks you very much for your help nikedshield & ExistentialDisorder :]
Attached Link: http://www.morphography.uk.vu/fileguide_1.html
Here's my guide to where to put things in Poser, for future reference. A'kin had threatened to do a French translation, but I haven't heard... :)@nglishBob- Thanks you very much for your guide it's very helpful. Now i know where tu put the files correctly. :] @ExistentialDisorder- Ok ill not forgot to buy the girl from daZ. And vicky...I think you have to buy it too right?. Do you know whre i can find free nice female model to start. I want to experiment a little before starting to buy a lot of things. :] Thanks you for you help all, i realy appreciate. :]
Attached Link: http://www.poserforums.com/
There is a free female character called HER available at the sixus1 site You might need to be a member to download it, but membership is free. There are also some free clothes for this figure there, too.Message edited on: 09/17/2004 08:35
Attached Link: http://www.3digitalcrafts.net/studiomaya/1download/mdb/index.html
There's also Studio Maya's Maya Doll. Free download, clothes too, on this page.Attached Link: http://forum.daz3d.com/viewtopic.php?t=1204&start=0
Sara is also a freebie with a whole lot of support, some free and some comercial.Attached Link: http://poser-ism.vis.ne.jp/download/download.html
I found the link for lalala! The lalala figure and other downloads are at the bottom of the page and some maya doll clothes are at the top of the page.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello just get poser and i dont know how it's working...imean i know how to play inside the software but to import model or things like this...im totaly lost. So look the picture..and tell me if there is a model..(the woman in one of the files)....and ho i can bring it to my poser scene. After this...i think ill be okay. LOL!!! Sorry all for this n00b question. :[
