Wed, Jan 22, 10:05 PM CST
Subject: Poser 5.0 with realpic background
micpic ( ) posted Tue, 21 September 2004 at 1:18 PM ยท edited Wed, 22 January 2025 at 7:29 PM
Wow, this is a absolut stupit problem. I put in the background a photo (jpg or Tif) start the firefly render engine. And see all, but the real pic is lost. I can see a complet white picture without my poses or i see the poses without my background. Please what is my mistake. I hope you can help me Regards Michael
xantor ( ) posted Tue, 21 September 2004 at 2:06 PM
In the render options, on the right hand side of the image output settings select render over background picture. Also, if you don`t have service release 4 for poser 5 you should download it now and install it before continuing with using poser 5.
micpic ( ) posted Tue, 21 September 2004 at 2:18 PM
Hi Xantor, thanks for your Message. I work with Poser 5.0 Servicerelease 4. (German) I activate the Button "Hintergrundbild" i think its the same as you meen. Its posibilty that the Problem is the picture ?. Its a normal tif with 72 dpi. Thanks Michael
xantor ( ) posted Tue, 21 September 2004 at 8:31 PM
I don`t know about the german copy but some people here are german and should be able to help. Tif files should work as a background. You could try going into the material room and select the background then delete all the nodes there, then try loading your picture.
ynsaen ( ) posted Tue, 21 September 2004 at 11:15 PM
When saving in tif format, you have an alpha channel, not a background. If you need tiff format, load a simple square into the scene, scale and size it , and load the background image onto it.
