Wed, Feb 5, 2:20 AM CST
Subject: Can Poser import an AVI file with sound?
moushie ( ) posted Fri, 01 October 2004 at 6:43 PM · edited Wed, 05 February 2025 at 2:03 AM
Is it possible, having made an AVI movie with sound, to import the AVI together with its sound into a new Poser motion file? When I import, I get the AVI but no sound.
xantor ( ) posted Fri, 01 October 2004 at 8:16 PM
If you save the avi sound as a wav, you should be able to import the sound and render an avi with the sound that way. Or you could just render the animation and add the sound later.
mofolicious ( ) posted Sat, 02 October 2004 at 1:03 AM
I would suggest using video editing software post render for the best results.
moushie ( ) posted Sat, 02 October 2004 at 10:27 AM
Thanks. Editing software won't help since I want to build Poser action around pre-recorded sound. As for WAV files, how do I make these? So far as I can determine Poser only saves files as pz2 and only makes movies as AVI. Have I missed something?
xantor ( ) posted Sat, 02 October 2004 at 1:04 PM · edited Sat, 02 October 2004 at 1:05 PM
Attached Link: http://www.virtualdub.com/
Virtualdub is a free avi editor ( at the link ) but if you just want to make an avi with sound then you can find out how to do it properly on page 240 of the poser 4 manual available at curiouslabs.com
Message edited on: 10/02/2004 13:05
moushie ( ) posted Sun, 03 October 2004 at 12:09 PM
I know how to make an AVI with sound. My question was how to import an AVI file together with sound into Poser for merging with a new motion file. It seems we've drawn a blank. Thanks for the comment.
smiller1 ( ) posted Sun, 03 October 2004 at 2:42 PM
You can't access the sound in the AVI file. You need to use editing software to create a sound file in the wav format which contains the sound. When you import the sound/wav file it provides the sound to the avi file you've already loaded. When you play the animation in poser you can then hear the sound.
moushie ( ) posted Sun, 03 October 2004 at 11:36 PM
But that doesn't work for me. I added sound to an AV file in my editor, VideoWave II, but the sound does not accompany the video when imported into Poser 4.
moushie ( ) posted Sun, 03 October 2004 at 11:39 PM
Correction. I've just realized I didn't add the sound in my editor. But then I can't, because I need to match the Poser action to the sound, and you can't do that in an editor. Can you ...?
xantor ( ) posted Mon, 04 October 2004 at 5:55 AM · edited Mon, 04 October 2004 at 5:57 AM
Attached Link: http://www.softlab-nsk.com/ddclipro/free.html
I think that poser can`t actually import the avi with its sound thats why I said earlier you could render the seperate frames of the animation and then add the sound later with a video editing program.
There is a very good free program that lets you add sounds at certain parts of the avi called ddclip at the link. You can match the poser action to the sound with ddclip.
Message edited on: 10/04/2004 05:57
xantor ( ) posted Mon, 04 October 2004 at 6:39 AM
With ddclip you can drag and drop wav files to the parts of the clip where the sound should be, so you don`t even need to remember the frame number.
Little_Dragon ( ) posted Tue, 05 October 2004 at 3:42 AM
  1. Open the AVI file in VirtualDub (File menu --> Open video file)
  2. Save the video's soundtrack from VirtualDub as a WAV file (File menu --> Save WAV)
  3. Import the AVI file in Poser (File menu --> Import --> AVI Footage)
  4. Import the WAV file in Poser (File menu --> Import --> Sound)
moushie ( ) posted Tue, 05 October 2004 at 10:59 AM
Interesting idea (Little Dragon). I'll give it a try and let you know. Many thanks.
xantor ( ) posted Tue, 05 October 2004 at 3:34 PM
The little dragon idea is what I said in message 2.
moushie ( ) posted Tue, 05 October 2004 at 6:40 PM
Many thanks, Little Dragon. And sorry Xantor, you're right -- but I had no idea how to save the AVI and WAV files separately in Poser. Little Dragon's VirtualDub suggestion made it possible. It's an elegant solution. My problem is resolved. This forum has never let me down. Thanks to everybody who offered help. I really appreciate it.
