The back wake looks great, but the sphere in front is wrong (as you already know :) I would just create some surf type terrains real close to the body of the ship, nothing too far in front of it. You might want to study an actual boat wake, that may give you a better idea. Also a wake from behind would come out in a triangle type shape, not two straight lines.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=678580&Start=1&Artist=ICM&ByArtist=Yes
I created a wake in this image some time ago. Not quite so dominent as in your scene. Here is the material setting.Also you could try duplicating your wake object, shortening the depth so the material is more concentrated near the craft. then use a completely transparent negative lattice and try to break it up a little.
Looks great! ps...could also alter & touch it up with post work. ICM
Message edited on: 10/10/2004 16:14
___
Ockham's razor- It's that simple
Not sure this will help, but you might try selecting "Fuzzy" from the menu in the down arrow to the left of your "LowClouds15" texture. This could keep the sides of your sphere from looking so stark.
Message edited on: 10/10/2004 17:13
I wouldn't bother with the wake at the front. At that speed all the disruption and trurbulance would be behind it.
The texturing on the model is great. Trying to figure out how the transition from shiny black to semi-transparent dome is achieved, I think I can see several thicknesses of hull? Oops - just occurred to me - did you make the spaceship from metaballs? I always forget that they exist. Would have been worth saving that into your Objects folder right away - you don't even need to do a general save of the file, just select and Add into your objects in the Create menu As someone who stands at the back of a big ferry quite often.......the wake has to start out very thick, high and white right at the engines, then it gradually flattens and increases in size widthways like ICM says. I can see though that your engines are way above the water, so don't know. I really like what's happening in the lower right of the picture, on the surface of the water. Don't give up. And don't forget to save save save save :^(
There is a fabulous example of this effect in the movie 'FIREFOX' starring Clint Eastwood. Even if the storyline was a turkey, the S.E.'s were excellent.
