Mon, Feb 10, 2:56 PM CST
Subject: Vue 5 and Poser Artist Materials Problem
Cowboyuk ( ) posted Sat, 16 October 2004 at 10:25 AM ยท edited Wed, 05 February 2025 at 2:46 PM
Has anybody had any issues with importing poser 4/Artist figures into Vue 5? If I import a default figure with the default textures, it will import without any problem. However, when I try to import the same figure, with different textures they lose all there textures on import. If I open the figure in poser, all textures are correct. Is it something I'm doing wrong (probably) or has anyone else noticed this same issue.
Thanks
Cowboyuk ( ) posted Sat, 16 October 2004 at 1:01 PM
Well, after reading Wabe's reply to Spider1313's problem, I reinstalled Vue 4, and the poser model loaded with all correct textures, saved it as a *.vob and loaded it into Vue 5 that way, with all the textures still in place.
wabe ( ) posted Sun, 17 October 2004 at 10:26 AM
But if there is a difference in behaviour between V4 and V5 you should report that to E-on. To make V5 as good as V4 was. Have you ever tried to rename the Poser characters in Poser before saving them? Maybe that is another workaround.
Cowboyuk ( ) posted Sun, 17 October 2004 at 3:02 PM
I couldn't get access to the technical support - it kept timing out, so have posted a message on the eon forum. Would be interesting to find out if anyone else has seen this problem while using Poser 4 or Poser Artist, or if it's just me...
