Mon, Feb 3, 11:42 PM CST
Subject: P5 Reflection Node
Doodles ( ) posted Mon, 25 October 2004 at 9:29 AM · edited Mon, 03 February 2025 at 9:21 PM
I got P5 a week ago, one of the reason I got it was because I wanted to use the reflection node. After reading two tutorials I found and following them to the letter, I still can't get the reflection node to reflect. I have this really great concept I want to render and it's driving me nuts because I can't it the thing to work right. One of the tutorials is from Poser Arcana http://arcana.daz3d.com/index.php?id=939. I found another tutorial that basically says to do the same thing. What am I doing wrong, anyone have this problem?
dbowers22 ( ) posted Mon, 25 October 2004 at 11:16 AM
This may be a dumb question, but are you rendering the scene? Reflections only show up in the final render, you won't see it in the working screen. If the reflection doesn't show up in the render, make sure ray tracing is checked in the render options. Also make sure the camera angle is correct so you can actually see the reflection, maybe it is reflecting but you are just not seeing it. It does work and works quite nicely. I have made all sorts of reflective objects, including people to get that metallic look like in the Sexy Robot series of drawings.
Doodles ( ) posted Mon, 25 October 2004 at 11:45 AM
It doesn't show up in the render....I must of render the image about 20 different times and I have followed the tutorials very carefully, checked my settings at all times. I haven't played with the lights though...so I will do that. Thank you for your response.
thefixer ( ) posted Mon, 25 October 2004 at 12:26 PM
You need to make sure that you have the reflection "quality" set to a high enough level in the material room. If this is set too low and the default is too low then the reflection won't look any good. For a really top reflection for a mirror for example have this set to 1. As dbowers22 said make sure ray tracing is on and up your ray trace bounces if you want a lot of depth to the reflection.
Injustice will be avenged.
Cofiwch Dryweryn.
gmadone ( ) posted Mon, 25 October 2004 at 1:21 PM
The screenshot of the material at the link results in white when rendered. Try turning the diffuse value to zero. (or at least something small)
Berserga ( ) posted Mon, 25 October 2004 at 1:48 PM
Make sure you have enough light on the object. It needs light to reflect into the camera. Make sure Raytracing is turned on in render properties as well.
maxxxmodelz ( ) posted Mon, 25 October 2004 at 2:10 PM
It's virtually impossible to tell what's wrong without seeing some screenshots of your scene settings in both the material room and the render dialogue.
OddDitty ( ) posted Mon, 25 October 2004 at 3:31 PM
hopefully this will help. Square's properties shown, that's a render in the corner (sorry about not adjusting the shadow cam).
Doodles ( ) posted Tue, 26 October 2004 at 11:09 AM
Thank you everyone for your suggestions and help. After following your suggestions and the screen shot above by OddDitty I was able to make the reflection node work. I'm going to have to play with the lighting a lot to get the final result I'm looking for but I'm off to a good start. Again thank you so much for the help.
ynsaen ( ) posted Tue, 26 October 2004 at 12:02 PM
P5 is much more lighting effected than P4 was, so lighting plays a much greater role in the end result. Glad ODF could help, even if they were using a stock lighting from P5, lol
