october, The problem is that Toon! doesn't understand transparency. The extra information that Toon! uses to create the Toon!ed image only has one layer of of information. So when the it goes to figure out where the edges are, it finds the edge of the partially transparent plane at the edge of the plane, not at the edge of your opacity mask and it doesn't know about anything obscured by the plane. I would have imagined that turning off the line effect on the plane would have made it blend with the wall. I did a little sample scene and came across the same effect. I'll take a look at it and see if there is anything we can do. Thanks, Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
Carrara and LightWave
plug-ins
october, I've posted an update to Toon! III that fixes the problem with the outline on overridden objects. You can grab the PC version at http://www.digitalcarversguild.com/downloads/DCGToon.zip or the Mac version at http://www.digitalcarversguild.com/downloads/DCGToon.sit Thanks, Eric Winemiller Digital Carvers Guild Freeware and commercial 3D extensions http://digitalcarversguild.com
Eric Winemiller
plug-ins
