I'm wondering why you didn't use an altitude render...does this method give sharper results?
edit to add - though an advantage of your method would be that you could add different bump-maps to individual bits prior to the initial rendering, that would be carried over into the terrain :^) Duh! Re-read your description again, and understand what you mean now.
Message edited on: 11/03/2004 03:23
I'm with Ang on this. What's a Greeble? Nice images BTW.
Message edited on: 11/03/2004 06:28
greebles are all the doo-dads and watchamacallits on the outside of a thingamajig... usually a space thingamajig, but sometimes architectural doohickeys are greebled too... and don't confuse your thingamajig with a thingamabob... that'll get you into some trouble...
Message edited on: 11/03/2004 08:14
And Ginger was so flighty...;) you knew she was coming onto you only to get something..you think the rest of the castaways would wise up and..where were we?..;)
Greebles are panels, pipe fittings, antennae..basically anything that 'breaks the surface' of the spaceship..hmm..hadn't thought about that.. could be part of my problem..;)
