Fri, Jan 24, 5:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 4:20 pm)
Subject: Document Window/Figure No Longer Display Properly
FlyByNight ( ) posted Wed, 03 November 2004 at 10:05 PM · edited Fri, 24 January 2025 at 5:13 PM
This is the display window I am getting as of today and though you cannot see it there is a figure in the window. I've uninstalled and reinstalled twice and no change. Although when I try to render even a simple ball prop it tells me I am out of memory. Pentium 4 CPU 2.40GHz 1.60GHz 1GB RAM Windows XP Pro I have never had this problem before until last night and this is a new computer. Any helpful suggestions on what is causing this?
FlyByNight
geep ( ) posted Thu, 04 November 2004 at 6:23 AM
Hi FlyByNight, You might try this. It looks different in P5 but it works the same way. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 04 November 2004 at 6:25 AM
cheers,
dr geep ... :o]
edited 10/5/2019
Djeser ( ) posted Thu, 04 November 2004 at 10:30 AM
You might also want to check for the memory patch for Poser @ Curious Labs. I changed my virtual memory and all of a sudden got a strange interface kind of like you have; I did a search on the forum here and found that there is a patch that will help with this. It's not the standard 4.0 to 4.03, it's a different patch that mentions memory settings specifically.
Sgiathalaich
FlyByNight ( ) posted Thu, 04 November 2004 at 1:28 PM · edited Thu, 04 November 2004 at 1:37 PM
Dr. Geep, thanks. I did change those settings to the factory state but the display remained the same.
Djeser, that's when it happened after I adjusted the virtual memory setting. Going to download the patch and see if that helps.
Thank you both! Yes! The patch did the trick. Thank you so much!
Message edited on: 11/04/2004 13:37
FlyByNight
Djeser ( ) posted Fri, 05 November 2004 at 1:54 PM
Great! I didn't know about it until I read it here...glad to be able to help.
Sgiathalaich
