You might also want to check for the memory patch for Poser @ Curious Labs. I changed my virtual memory and all of a sudden got a strange interface kind of like you have; I did a search on the forum here and found that there is a patch that will help with this. It's not the standard 4.0 to 4.03, it's a different patch that mentions memory settings specifically.
Dr. Geep, thanks. I did change those settings to the factory state but the display remained the same.
Djeser, that's when it happened after I adjusted the virtual memory setting. Going to download the patch and see if that helps.
Thank you both! Yes! The patch did the trick. Thank you so much!
Message edited on: 11/04/2004 13:37
FlyByNight
FlyByNight
