Attached Link: http://www.renderosity.com/viewed.ez?galleryid=26964&Start=1&Artist=Jen&ByArtist=Yes
Thanks Jim I finally just tried to paste jaagers nip texture on the body tex I was using and it came out alot better. If you want to see the finished pic you can view it at the url.Yup. Only directly usable on Millie. The textures are of a shape that matches the area on Victoria. They are just much larger. Cut-N-Paste with a good paint prog and adjust the size with a corner box. The bottom texture is of no use on Victoria, but can be transfered to Eve. I thought I 'splained' the textures in the text file.
Thanks OK, I was wrong above. The lips will also transfer to a Victoria texture by cut-n-paste as well. It is the other separate texture that has no location on Victoria. Victoria/Millie & Michael are definitely more complex as far as setting the textures is concerned. Poser 3 was difficult enough to get started with back before Poser 4 was released , it must be really interesting now. Most of the advanced techniques were introduced here, and by the members. The commercial developers have mostly been gleaning.
