Sun, Jan 26, 7:08 PM CST
Subject: +++ DG#105 +++ The Setup Room (cont'd) +++ Page 31 ...
geep ( ) posted Sat, 06 November 2004 at 4:00 PM · edited Sun, 26 January 2025 at 7:07 PM
Hi Folks, I hope you are enjoying this tut and ... You can ... ... find [ Pages 21-30 if you CLICK HERE.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1989913) cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Charlie_Tuna ( ) posted Sat, 06 November 2004 at 4:08 PM
Why shouldn't speech be free? Very little of it is worth anything.
Staby ( ) posted Sat, 06 November 2004 at 4:21 PM
Bookmark
wrpspeed ( ) posted Sat, 06 November 2004 at 5:51 PM
bookmark
mikeberg ( ) posted Sat, 06 November 2004 at 7:02 PM
Still with you doc!
jentron ( ) posted Sat, 06 November 2004 at 7:10 PM
New student...
modus0 ( ) posted Sat, 06 November 2004 at 8:24 PM
________________________________________________________________
If you're joking that's just cruel, but if you're being sarcastic, that's even worse.
PIXELPUNK10010 ( ) posted Sun, 07 November 2004 at 1:42 AM
Hey Doc, any chance we will see this in a PDF format? Its a very timely tutorial. I was just working on converting some lightwave models into Poser figures.
geep ( ) posted Sun, 07 November 2004 at 9:06 AM
(Note - graphic posted without permission - hope I don't get in trouble. ... ;=] ...) Hi Steve, Crescent, over at her [Ebonshire website](http://www.ebonshire.net/tut-geep/index.php) is graciously hosting most of my tuts as .pdf's. I do not know when (or if) she'll do this one in the future. Someday, I hope to do a CD with all(?) my tuts on it (for a nominal fee, of course, ha ha). Until then, stay tuned right here to Renderosity, the best big little 3D graphics site on the web. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 07 November 2004 at 9:09 AM
cheers,
dr geep ... :o]
edited 10/5/2019
Tashar59 ( ) posted Sun, 07 November 2004 at 11:41 AM
See you when you get back.
nakamuram ( ) posted Sun, 07 November 2004 at 2:38 PM
Good Luck!!
Crescent ( ) posted Mon, 08 November 2004 at 1:05 PM
Actually, I was about to check with geep and make sure was okay if I put up a few more batches of tutorials now that I've finally moved everything over to my new site. Since I'm still getting free publicity, it looks like it's okay. ;-) I'll wander back in when I've been able to get some of the tutorials up. Cheers!
PIXELPUNK10010 ( ) posted Mon, 08 November 2004 at 3:30 PM
YEAY!! Thank you. I always prefer to download the PDF to my laptop and have it available off line. I appreciate your hard work! - Steve
Crescent ( ) posted Mon, 08 November 2004 at 4:07 PM
I converted a few more tutorials to .pdf and put them on my site today, but since this tutorial isn't finished yet, I haven't done a conversion. When Doc gets back and gets this one finished, I'll be glad to get it converted. Cheers!
Tereesa ( ) posted Tue, 09 November 2004 at 1:44 AM
Thank you! :D
geep ( ) posted Sun, 14 November 2004 at 11:47 AM
cheers,
dr geep ... :o]
edited 10/5/2019
Charlie_Tuna ( ) posted Sun, 14 November 2004 at 12:50 PM
The doctor is back in :-)
AntoniaTiger ( ) posted Sun, 14 November 2004 at 1:40 PM
I think that Weld Group trick might be worth trying on something I have....
geep ( ) posted Mon, 15 November 2004 at 5:13 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 15 November 2004 at 10:51 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 15 November 2004 at 12:57 PM
cheers,
dr geep ... :o]
edited 10/5/2019
libernull ( ) posted Mon, 15 November 2004 at 1:59 PM
Questions from the back: At what point should you Weld? Do you need to create a new group to Weld? Can you use the 'Body' and Weld that? Is there any reason why you would want to undo a Weld? If so, how? Dr.Geep - this is truly an epic tutorial, thank you!
geep ( ) posted Mon, 15 November 2004 at 4:40 PM
Hi libernull, Thank you for the compliment ... ;=] ... AND the inquiry ... ... you have asked some very good questions. ;=]
Here are the ... Answers to the back: Q. "At what point should you Weld? " A. I am not sure because I did not write the code ... but, having said that, I believe you can do the "Weld" operation at any point in time. Q. "Do you need to create a new group to Weld? " A. Yes, and no ... Yes, if a group does not exist that includes all the polygons in the figure ... and no, if the figure already has a group (like the "Body") that includes all the polygons. Q. "Can you use the 'Body' and Weld that? " A. Sure, why not ... see the answer to the previous question. Q. "Is there any reason why you would want to undo a Weld? " A. A very, very good question ... and Yes, if you wanted to use the same figure (mesh) but change the configuration of the body parts, you might want an "unwelded" figure. Q. "If so, how? " A. Ah, yes, unwelding a mesh ... The easiest way is to export the figure as a (single) "Wavefront OBJect..." and then use UVMapper (a free program) to "split vertices." Now you can Import the OBJect back into Poser without the vertices welded. - - - - - -
cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 15 November 2004 at 4:42 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Mon, 15 November 2004 at 10:46 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Tue, 16 November 2004 at 10:56 AM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Tue, 16 November 2004 at 3:12 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Wed, 17 November 2004 at 1:13 PM
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Wed, 17 November 2004 at 6:38 PM
Hi Folks, If you're not falling asleep yet, you can CLICK HERE for Page 41. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
