Wed, Jan 29, 11:44 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: Eyebrows size?
narvik ( ) posted Wed, 06 December 2000 at 5:11 PM ยท edited Wed, 29 January 2025 at 11:37 PM
Hey all. Okay the modifications with the magnets worked very well. Thanks JeffH for the help. Now for the eyebrows; how can I easily change the size of an existing Poser4 model's eyebrows. Is there some sort of texture that can be modified? Best, Marius
JeffH ( ) posted Wed, 06 December 2000 at 8:45 PM
In what way do you want to change the size? P4 Male or Female?
narvik ( ) posted Wed, 06 December 2000 at 8:59 PM
Thanks for the reply, JeffH. It's Poser 4 Male; and I want to make them fuller/thicker; although I must say also that in the meantime I have purchased 'Micheal', and it might be easier with 'him' I'm still playing araound with it right now. Marius
Jaager ( ) posted Wed, 06 December 2000 at 10:04 PM
With Michael, it is pretty straight forward. Morphs are not needed. One way to do it: 1.Just make the brow texture on the head the same as the skin surrounding it. 2.Either make a fur texture or jusr Poser color for the Upperbrow. 3.Control the size of the brow as well as the density by the use of a transMap: white shows, black does not. Trans slides set Min/max = 100% highlights = 0,0,0 (black) 4.Set the upperbrows so that they are just barely touching the head. If you have a paint program which supports layers, you can mix and match border shape, fur density, fur direction and get several versions with not so much work.
JeffH ( ) posted Thu, 07 December 2000 at 5:58 AM
Attached Link: http://www.renderosity.com/funstuff.ez?Search=Yes
There are several full brow texture maps for the Michael figure in the FreeStuff. Do a search for "Mike" and "Michael" separately to get them all. http://www.renderosity.com/funstuff.ez?Search=Yes -JH.
